Question about Vivitar ViviCam 35 Digital Camera
Wont install every time i run the cd rom disk it came with my computer keep saying it dont have an (authenic code) for it what does that means excuse me if i misspell the word
    Genius:
  • 2,985 Answers
Forget the CD Rom
This suggests you are running a PC with XP and it is not a signatured software.
Windows however can download images without the software
Just plug it in and let Windoes do the work
Posted on Jan 22, 2008
My laptop wont burn cds?
What are the file formats you are trying to burn? Are they copyrighted ? You can download Windows Media Player and many more freeware programs at FILEHIPPO : http://www.filehippo.com/. Look under "Audio and Video". That said is your laptop equiped with a DVD/CD burner? I was lookin at the specs: http://h18000.www1.hp.com/products/quickspecs/10826_div/10826_div.html It doesn't say you have a CD burner , ony a CD rom drive. That does not mean you don't have one. Open My Computer and right click on the CD ron , Properties, and Google the model of CD rom.
Dec 12, 2012 | Compaq Armada 110 Notebook
I am trying to reboot my computer
you should call your costumer support for recovery disk.
it will work.
Jun 03, 2010 | Toshiba Tecra 8000 Notebook
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
Is it possible to install windows operating system on an asus eee pc 701sd and how would it be done with no disk drive
Insert the windows disk in the CD-Rom drive in the computer, then press F12 when you first turn it on. keep pressing it until a menu appears. In the menu, select whichever option is the CD-Rom drive. then follow the onscreen instructions to install Windows.
Feb 21, 2010 | Asus Eee PC 701Sd Notebook
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Mar 09, 2009 | Sony CRX320EE CD-RW/DVD-ROM Combo Drive
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Help with installation.
Do u have a Driver Disk of ur Printer?
if yes run the cd driver to ur cd/dvd rom in click install driver just follow the instruction of the installation.
Mar 04, 2008 | Office Equipment & Supplies
My cd/dvd rom is not found in My computer but it is installed (code 39)
What programs can I use to burn or create CD's on my computer? A standard CD-ROM drive is not capable of creating a CD even if you have any of ... If you're running version 10 or higher and have a CD/DVD burner drive .
Good Luck, Please dont for get to Vote/Thank You
Dec 20, 2007 | Computers & Internet
Dvd/cd rom drives
i cnt run my dvd rom drive but only cd.disk
Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
Vivitar ViviCam 35 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
