Question about Tricity Bendix AW1400W Front Load Washer
Tricity bendix aw1400w will not spin
I have a tricity bendix washing aw1400w wont spin it only seems to turn on wash cycle but does not go to fast spin. i had a problem with pump but now sorted just wont spin and lights flash on front possibly like a short. can you help please
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
There is fairly high chance the pump filter is blocked, open the flap on bottom right place a bath towel around area and use a small frying pan to collect water. SLOWLY ease filter cover anti-clockwise and collect water in frying pan a little at a time. once its all gone remove the filter get all the junk and coins from it-rinse it in clean water and re-assemble.
Posted on Nov 07, 2008
  • 1,665 Answers
Check If drive belt is in good condition.Also check if no spin option is selected.
At the link below you can download your user manual in pdf format.
Posted on Jan 22, 2008
It needs resetting
go to this site and follow instruction
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Washer stoped working wont fill up wont spin it bleeped a few times now wont go on a cycle
The door catch (interlock switch) is the usual suspect for that fault. If it can't detect the door is shut it does not fill.
Dec 05, 2010 | Tricity Bendix AW1400W Front Load Washer
My Tricity Bendix AW1400W washing machine will wash but not drain. I was told I have a faulty pump which I immediately changed but the problem still persists. Can you help?
If you have replaced the pump check that the pump is actually working the easy way to tell is to remove the filter and shine a torch up inside put machine on spin or drain and see if the impellor on the pump is rotating if not then the problem could be in the wiring or the main programmer is faulty.
Apr 14, 2010 | Tricity Bendix AW1000W Front Load Washer
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Wont spin
the pressure switch tube will require a blow through,thats if the pumps ok and clean.or a freak happening would be a blocked waste pipe( i have seen this before after much head scratching!)
Aug 27, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
not only check filter but when filter out check for foreign objects fouling pump impellor. (bra wires are the favourite) if pump impellor not visible, then put onto drain and listen for a low humming noise in vicinity of pump. this confirms that pump is powered but jammed. all you can do after that is to check continuity of pump and check there is power to pump when on drain - assumes you have a multimeter
May 03, 2007 | Tricity Bendix AW1000W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1400W Front Load Washer Logo
864 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
