Question about Dell 3100cn Laser Printer
Roller Fell Out (with my help)
Rear door would not shut. Tried to force it and still would not close. I pushed on one of the white rollers (barrell is 1.5 in. wide not including 5/8 in. prong on each side) that rests against a metal bar with 2 black rubber rollers that press against the barrell that fell out (these rollers feed stock). Barrell is fine but need to reinstall it. I have since figured out how to massage the door to get it to shut. I took main unit off of paper tray unit but still did not observe access. Any help would be most appreciated. lawjp@earthlink.net
  • 1 more comment
  • sifuchar Jan 29, 2008
    I have not had the roller fall out, but do have the same problem getting the rear door to shut. I find it helps to shake the door horizontally as I apply gentle pressure to close. I am unable to determine what exactly is blocking it.
  • nfcb Feb 05, 2008
    I am experiencng the same problem. There is nothing blocking the door and door just won't snap close. Very frustrating.
    Tried, pressing levers inside printer by removing trays. Just does no work.
  • Anonymous May 07, 2009
    I have the same problem with the reg cover message..what is the reg cover...HELP!
Pick up the printer, lay it on its front and close the reg cover. Simple as that but it took me ages to figure it out!!!!
Posted on Feb 19, 2009
Hi!
I have the same problem but found the source of it:
There is a small blend inside at the buttom.
This blend should be in a upricht position, but falls back when reg cover is open.
Therefore it blocks the reg cover.
If you turn the printer over to you(almost 90°) this blend falls back and you can close the reg cover.
Would be great to get instructions from Dell how to fix this!
mamimo_AT_gmx.at
Posted on Feb 20, 2008
My solution is a little different with regard to closing the rear door. If you provide enough clearance for the rear door to open all or the way, take your hand and dribble the rear door against the back of the unit and your hand like it was a basketball (don't let it fall quite all of the way open so that you do not put tension on the hinge). Eventually something in the unit moves and allows the door to close. DO NOT PUSH ON THE ROLLERS. Even though they look like a likely culprit, they are easily dislodged and can fall out. I am still hoping someone will give me some guidance so I can reinstall my roller. PLEASE, PLEASE, PLEASE!
My garage roller door will open but not close what is wrong?
Assuming you mean your home sectional door, not roller door. A roller door is what commercial companies use on docks or storage buildings. Also assuming you mean that your motor unit (the opener) won't close it, not that you can't pull it down manually. With all of those assumptions, I would say either your sensors are misaligned or blocked, or your force needs adjusting, or your springs need adjusting. If you give more details on your questions, you are likely to get more specific responses.
Feb 19, 2015 | Building Materials
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
The slideing door wont close.When you pull the door close,the rear of the door wont go in unless you push it in at the same time its being close
Check the door tracks dirt/gum/crayons etc.
Check the rollers and roller arms, make sure they are not worn or loose or bound up. The rear roller arms should collapse freely to allow the door to latch.
Clean the track rollers and arms with a spray degreaser then wipe clean and spray with a penatrating oil wd40/screwloose etc. This should
cure the problem, if nothing is broken. Repeat this
a couple of times a year, more often if you take it to
the beach a lot. hope this helps. Good luck
Jan 23, 2010 | 1994 Plymouth Voyager
HP Business Ink-jet 1200 1) when it starts printing and the paper feeds it makes an extremely loud clunk sound regardless of the paper tray being used. 2) each and every time the paper comes through it...
The pickup roller is problematic. First clean, then replace if necessary.
The part should be under $20.
To replace (from HP Support):
1. Unplug the power cord from the
printer, and allow the printer to cool.
2. Open the toner cartridge door, and
remove the toner cartridge.
3. Locate the pickup roller.
4. Release the small, white tabs on
each side of the pickup roller by
pushing them away from the roller,
and then rotate the pickup roller
toward the front.
5. Gently pull the pickup roller up and
out.
6. Position the new pickup roller in the
slot of the previous pickup roller.
Note Circular and rectangular pegs on each
side prevent you from incorrectly
positioning the pickup roller.
7. Rotate the top of the new pickup
roller into position until the white
tabs on each side of the roller snap
the roller into place.
8. Reinstall the toner cartridge, and
close the toner cartridge door.
9. Plug the printer in to turn it back on.
Hope this helps.
Aug 16, 2009 | HP Business Inkjet 1000 - Printer - colour...
2002 Honda Odyssey: sliding door jolts/reopens when closing
Please check the aft track roller assembly. It is easiest to inspect from the rear of the van looking forward when the door is open. You'll see the rear hinge assembly clearly. The track rollers cannot be seen but you can pull outboard on the rear edge of the door--the door should not move outboard more than 1/8 of an inch. If it moves out more than this or feels sloppy, suspect damaged/missing track rollers. This will cause the hinge to chatter in the track and "jolt". It will also cause the door to misalign during the close phase preventing the close motor from properly engaging.
Replacing this part is no easy task but doable if you are good with cars. Check back here for more details if you want to try it, otherwise get a competent mechanic or the Honda dealership to do it.
Jul 20, 2009 | 2002 Honda Odyssey
2005 sequoia rear latch
purchase a paint roller tool where the roller part is only about 4" or so long. tear off the soft roller. bend the bar another 45 degrees so the angle from the handle to the part that had the roller on it is about 135 degrees. make sure all 4 doors are unlocked.
get on your knees and look on the right side of the handle where it goes into the door. you will see where you will insert the paint roller. now stand up. facing the door hold the paint rollerhandle in your right hand so it is sticking straight out from the door horizontally . insert the business end into that hole vertically. you will then feel for the "pad" which you are going to depress inside the door. when you feel it, turn the handle you are holding to the right slightly because you are now gong to push on that pad towards the front of the car. in order to do that, you need more clearance and that is why you are moving the handle. use your left hand to stablize your tool at the bend. at the same time put some of your weight on the door as if you were pushing it closed. you will hear it unlatch. lift the door as if the door handle worked. voila. the door is open.
Mar 28, 2009 | 2002 Toyota Sequoia
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Epson aculaser cx11nf MP E paper jam
open the mp tray
locate 2 white plastic egg shaped piece on the ends of the steel rod
gently push one or the other towards the back of the machine
if the paper jam error message is on then the roller will turn as soon as you give it a push
re load the paper
open and close door a or e
printing should resume
that white piece works with the paper lift to get the paper up to the in feed roller
Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
Dell 3100cn Laser Printer Logo
426 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
