Question about Casio FX-300MS Calculator
Reset?! My calculator answers in scientific notation. How do you reset your casio fx-300Ms (S-V.P.A.M)?
  • 1 more comment
  • quarantine13 Feb 01, 2008
    THANK YOU!
  • Anonymous Mar 16, 2014
    how to make answers in decimal form not scientific notation
  • DougDuff
    DougDuff Jun 04, 2018
    It's the common problem every student face with a scientific calculator. You need to press shift+mode then it show you mcl modes based up on your requirement you press 2 to clear the mode. For more support refer ninjaessays blogs where you can find any answer to your doubts relating to education.
Thank You so very much, this solution fixed my problem.
Posted on Feb 13, 2009
Shift +MODE CLR
opc (3) (all)
press =
thats all
Posted on Feb 16, 2010
How do i reset my calculator
Posted on Mar 26, 2009
Thnx
Posted on Mar 02, 2008
Go to the top part, there look for the "MODE" key, press it three times until you see " Fix (1) Sci(2) Norm(3)", then choose the third option by pressing 3, and then you'll see "Norm 1 - 2?" and press 2
Posted on Jan 31, 2008
  • Nicole Mar 01, 2012
    Thank you! You helped me out alot :)
  • tessdesh
    tessdesh Jul 17, 2012
    Thank you very much! :-)
How can I change the threshold for scientific notion rounding in normal display mode on my Casio fx-9750GII.
[PDF]fx-9860G Series_fx-9750GII_fx-7400GII_Software Ver. 2.0_Eng - CASIO
support.casio.com/pdf/004/fx-9860GII_Soft_E.pdfThe contents of this user's guide are subject to change without notice. ... For full details on availability in your area, contact your nearest CASIO ...... The calculator normally displays values up to 10 digits long. Values that exceed this limit are .... The fx-7400GII and fx-9750G II are not equipped with a Math input/output mode.
SOLVED: Scientific notation on the casio fx-9750GII - Fixya
www.fixya.com/support/t20210775-scientific_notation_casio_fx_9750gii
Sep 20, 2013 - Press [SHIFT][Menu] to open (Setup). Scroll Up to reach the line Display, press [F2] (Sci), type in the number of decimal digits, press EXE. See the screen captures below. Scientific notation on the casio fx-9750GII
Mar. 13, 2017
SOLVED: How do i turn off the scientific notation
Mar. 30, 2015
Using Scientific notation on the casio fx-9750GII
Oct. 5, 2013
Casio FX-9860G Graphic Calculator Scientific ...
Oct. 18, 2011
More results from www.fixya.com
How can I use scientific notation on casio calculator? ' Socratic
https://socratic.org > ... > Correct Use of a Scientific Notation on a Scientific Calculator 7 days ago - Most scientific calculators have a button EXP ...type in a number, press EXP , AND then you asked to input the exponent as a power of 10 .
videos
casio fx 9750gii scientific notation Google Search
Jun 18, 2018 | Casio Computers & Internet
How do i convert a number in scientific notation using the calculator?
You can always enter a number in scientific notation. Use the EE or the [x10^X] key to enter the exponent of 10. Whether it will remain in that form depends on the display mode you set the calculator into:SCI, ENG, NORM1, NORM2, FIX.
However if a result is too big or too small, it will always be represented in SCIentific format.
Sep 09, 2011 | Casio FX-300MS Calculator
My Casio fx-95MS Wont come off scientific notation i need help
the best option would be to reset your calculator. there is a small panel on the back with a screw. open that up and take out the battery. press the on button to ensure you have drained the power. put the battery back in and it should be reset and working normally
Aug 15, 2011 | Casio FX-115ES Scientific Calculator
How do you get a casio fx-300MS out of scientific notation form?
Press Mode a number of times until you see below:
Then press 3 to select Norm.
May 19, 2011 | Casio FX-300MS Calculator
I am using my Casio fx-300MS and have somehow gotten into the display where it puts my answers in exponential form; 5+5 = 1.0 exp10 to the 1. How do I return to getting my answers in standard form?
Display Format
To change the exponential display format, press the [MODE] key 3 times.
Fixed number of decimal places:
Press 1: Scientific Notation: 0
Press 2: SCI: 0
Press 3: NORM
You will then be prompted for NORM 1 or NORM 2. CHOOSE NORM 1
To return the calculation mode and setup to the initial defaults, press [SHIFT] [CLR] [2]
[=]. This will return the calculator to the following settings:
Calculation mode COMP
Angle unit Deg
Exponential display format Norm 1
Fraction display format a b/c
Decimal point character Dot
Percentage Calculations
Apr 13, 2011 | Casio FX-300MS Calculator
How can I get my calculator out of scientific notation mode? It is a casio fx 300ms
Please press the Mode button on your calculator repeatedly till you get the following screen
Fix Sci Norm
1 2 3
Press 3 from your keypad and the screen will change to
Norm 1~2?
Press 1 from your keypad and your calculator will be normal again i.e out of scientific notation mode.
Mar 15, 2011 | Casio FX-300MS Calculator
How do i get my calculator to stop displyaing 15!/5! as 1.08972864*10*10?
You don't. The calculator can display only ten digits in a number. This number has eleven digits to the left of the decimal point, so the only way the calculator can display the most significant digits is to switch to scientific notation.
Oct 06, 2010 | Casio FX-300MS Calculator
After working a simple problem adding numbers in scientific notation, I want to convert the answer, a decimal, to scientific notation
For converting answer in to scientific notation do the following steps.
1.click shift key after that press mode key next to on button.
2.From the menu that is displayed in the screen press 7 for displaying answer in scientific notation.
Thank you.
Jun 10, 2010 | Casio FX-115ES Scientific Calculator
How do you enter a number in scientific notation on a casio fx-82B?
how do i get my fx-300ms calculator do to expanded notation?
Nov 10, 2009 | Casio Office Equipment & Supplies
Casio FX-300MS Calculator Logo
6,445 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
