Question about Canon PIXMA MP830 All-In-One InkJet Printer
Repeated Fax TX report printing
My MP830 is constantly attempting to print a TX error report (for a fax that was attempted two weeks ago). Is there some way to delete the error report buffer? I cannot find a way to stop the attempted printing.
use case:
- press Fax button on front panel
- error page is printed
- press Fax button again
- error page is printed again
I cannot tell if it is printing a page for the same error, or for a repeated (redial) error. But then, I can't find any list of pending error reports (no documents are found via the menu options).
  • 1 more comment
  • db2dba01 Jan 23, 2008
    I have the same problem. The machine keeps switching to fax and prints the report out again even when I have it in the copy mode. This is happening over and over again.
    I have gone into the control panel but there is no output for the fax printer.
  • Anonymous Mar 03, 2008
    I have the samne problem - continue to get a "fax error report" for a fax that didn;t go through a few days ago. How do I stop the machine from repeating the error report?
  • RobinEE Jul 15, 2008
    I have the same problem -- a fax that was incomplete over a week ago, yet I still keep getting incomplete transmission and error reports printed. I tried the suggestion of turning the machine off, unplugging, and waiting a few minutes before plugging back in and turning on. But it just printed out another error report. Any other suggestions out there?
Solution #3 solved it for me. The report kept printing over and over, so I used the menus (roughly) mentioned in Soluton #3 by guest.
My problem was the printer was trying to print the TX Error Report with the image attached. That made the report too big for standard sized paper, so the machine kept telling me to check the paper size, and I'd hit 'OK', and that made the machine try to print the report again, for it continued to think it had not printed a complete report.
Here's what I did...
Go to: Fax Menu
Arrow right ( >) to Maintenance/Settings, hit, 'OK'
Arrow right to (>) to Device Settings, hit 'OK',
Fax Settings, hit 'OK',
Arrow down ( v ) to TX Settings, hit 'OK',
Arrow down ( v ) to TX Report, OK
Select 'Print error only', hit 'OK',
Attach TX image, Select 'NO', hit 'OK"
With the instruction to not attach the TX image, it will print out the error report without the TX image, the report will fit on the paper, and it will clear this problem.
Posted on Apr 06, 2009
For Canon Pixma MP830 - the 1.13 firmware (or later) should do the trick.
Here's the link for the update utility: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12804#DownloadDetailAct
Later - B36.
Folding at Home?
www.foldstrong.org - join us!
Posted on Sep 30, 2008
Change the TX Report
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603#SupportDetailAct
1. Press the <FAX> button, then press the <Menu> button .
2. Use the [ Repeated Fax TX report printing - left.gif] or [ right.gif ] to select [TX SETTINGS] then press <OK>.
3. URepeated Fax TX report printing - left.gif ] or [ right.gif Repeated Fax TX report printing - right.gifUse the [ left.gif] or [ ] to select [PRINTRepeated Fax TX report printing - right.gifLY] or [PRINT FOR EACH RX] then press <OK>.
5. Use the [ left.gif] or [ right.gif ] to select [YES] or [NO] for [ATTACH TX IMAGE:] then press <OK>.
6. Press <Stop/Reset>.
Posted on Jun 06, 2008
Canon tech support walked me through this. Turn unit off. Unplug for 30 sec. Plug in, turn on. Memory should be cleared.
Posted on Mar 03, 2008
Thanks for trying -- but I turned my unit off and unplugged it for a couple minutes...and the first thing it did when I turned it back on was to print that pesky fax error report...
- Skyward
Posted on Apr 12, 2008
6ya staff
SOURCE:
How to retrieve 1 week ago fax history from brother 2280 fax machine
Printing reports
How to print a report
1 Press Reports.
2 Press ? or ? to select the report you want.
Press Menu/Set.
-OR-
Enter the number of the report you want to print.
For example, press 2 to print the Help List.
Following reports are available
1.Transmission
Prints a Transmission Verification Report for your last transmission.
2.Help List
Prints the Help List so you can see at-a-glance how to quickly program your machine.
3.Quick-Dial
Lists names and numbers stored in the One-Touch and Speed-Dial memory, in numerical order.
4.Fax Journal
Lists information about the last incoming and outgoing faxes. (TX means Transmit.) (RX means Receive.)
5.User Settings
Lists your settings.
6.Network Config (MFC-7225N only)
Lists your Network settings.
Jun 11, 2011 | Office Equipment & Supplies
Proof fo fax sent 2 month ago (Canon MP830)
Sorry sir, you are not able to retrieve back those fax records.
May 28, 2010 | Canon PIXMA MP830 All-In-One InkJet...
How to get a confirmation print out after a fax done
Open 1 Touch Speed Dial Panel. Press <Data Registration>. Press <Set>. Arrow down to (2.Report Settings). Press <Set>. 1.TX Report . Change from "Print Error Only" to "Output Yes". This will cause a confirmation report to be printed after every transmitted fax.
Oct 06, 2009 | Canon LaserClass 2050 Plain Paper Fax
How can I print a fax confirmation on a specific outgoing fax
Checking a report for the transmission result (?TX Report? function) A report containing the transmission results can be printed. The machine can be set to either print or not print the transmission report or to print it according to the machine setting or only when a transmission fails. To print the transmission report 1 Press the [Fax/Scan] key to display the Fax mode screen. 2 Touch [FAX Menu]. 3 Touch [TX Report] on the Set 1 tab. 4 Select how to output the report, and then touch [Enter]. ? Default: The transmission report is printed according to the previously specified method. For details, refer to ?Specifying report output settings (Report Settings)? on page 10-48. ? ON: The transmission report is printed with each transmission. ? If TX Fails: The transmission report is printed only if the fax could not be sent. ? OFF: The transmission report is not printed, regardless of the transmission result.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 10, 2009 | Minolta bizhub 200 Copier
How do I print a transmittal report after each fax sent?
Press the Menu button; use the right or left arrows to select device settings. Use the up or down arrows to select Fax Settings. Then TX settings.
Select TX report, then select to print a transmission report after each transmission, then select attach TX image. (This will attach the first page of the fax).
TX report Sets whether to print a transmission report after each transmission.
When Print error only or Print for each TX is selected, specify the following.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 21, 2009 | Canon PIXMA MX850 multifunction InkJet...
Report of fax
Hey renzo737 - Follow these steps to have your machine print a report after you send each fax:
1)Hit the Fax button, then the Menu button.
2)Press the < and > buttons to scroll until you reach
TX Settings. Hit OK.
3)Use the < and > buttons to scroll until you reach TX REPORT.
Then hit ok.
4)First you want ATTACH TX IMAGE and then you want
PRNT FOR EACH TX.(it may also say as TX REPORT)
On your machine under TX report it may just say PRINT ERROR ONLY, which means only print if there's an error, or the PRNT FOR EACH TX. You'll find it easily. You want the print for each tx option. This will print a report and give confirmation that your fax went through after each fax. If you have any problems understandind this or need more help just give a shout.
If this solves your problem PLEASE rate this as fixed. Like I said if you need more help just add a comment and I'll be happy to assist you further. Thanks and have a good one.
Jeff
Jun 30, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Apr 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Fax memory
This thread might be dead but I found that you CAN turn off report printing, which also frees up the memory, in the Fax->Menu->Maintenance/settings->Device Settings->Fax Settings->TX Settings->TX Report. Turn reporting off and it clears memory also. Hard to find but its there.
Jun 25, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
3,133 people viewed this question
Clive
Clive
old marine
old marine
Ekse
