Question about Fuji FinePix A600 Digital Camera
Fujifilm a600 problem since new
When its turned on the battery indicator shows they are low and it also never remembers the time and date. Even when it rarely works for a few minutes when turned off and on again it prompts for set up of date etc??
i've tried every kind of battery even the lithium ones?
please help!
  • fmartin1 Jan 29, 2008
    In my fuji camera, A600 model, the batteries are always low and prompts me for time and date and then switches on..I've tried new batteries and still the same..very annoying
    President:
  • 423 Answers
If still under warranty, Fuji can perform a "power re-set" on the camera. This reduces the amount of power the camera requires, and should solve the problem for the long-term. I have sent out one of my customer's A600 with the same conditions. The re-set solved his problem.
Posted on Jan 27, 2008
Date/Time resets every time i turn on camera.
Hi, yes, there is a small coin memory battery, usually something like a CR3032 lithium battery. Turn off the camera and insert a new 'coin' battery (correct side up). Close battery cover, turn on camera and go to menu and set time and date. It should remember the time and date for a year or two, provided you put a regular battery on the camera on a regular basis. Also note, some older Sony cameras allow you to set it so that it shows only the date for the 1st 5 seconds when you first turn on the camera that day, then shuts it off unless you want it to superimpose the time and date on the video. Good luck, and let me know if this solves your problem. John
Jan 17, 2012 | Sony Handycam HDR-XR520 High Definition...
I have a Fujifilm Finepix A600 and when I turn it on I get CARD ERROR Can you tell me how to fix it
You may have improver card fitted. Please remove and re fit the card. If problem persist , please try another good / new card. If you have no problem with new card, your existing/previous card is broken.
Regards,
Apr 19, 2011 | Fuji FinePix A600 Digital Camera
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
Kodak Playtouch camera. I missed the setup for the language and the date & time setup. How do I go back and set the language & date & time.
reset
We are an experienced group of internet sellers. All of our items are directly purchased by various reputable manufacturers throughout the world
Fujifilm FinePix J32 Digital Camera Battery Charger
http://www.fujifilm-battery-charger.co.uk/Charger/Fujifilm/Fujifilm-FinePix-J32.html
Sep 21, 2010 | Kodak Cameras
Canon Powershot A570 keeps showing change the batteries
I had the same problem. Here's the solution. Go into menu settings, then over to tools, select reset all at the bottom of options list. You may have to re-enter the date and time. This solved the low battery problem for me. I hope this helps.
Apr 02, 2010 | Canon PowerShot A570 IS Digital Camera
Hi I ave problem on fujifilm camera . It shows zoom error . Can you help pls ? thx
Hello
Thank you for using FixYa for your problem
Zoom lens bumped
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Fuji FinePix A600 Digital Camera
I have a Dell dimension 9150 which is 2 1/2 years old. Does it have a battery that I need to be concerned about replacing. I remember that used to be a problem with computers but don't know if that is...
Every PC motherboard has a battery. That battery serves two purposes: to feed the configuration memory (also called CMOS) and to feed the real time clock of the computer (the one that show the date and the time).
An indication it is time to change the motherboard battery is receiving one of the following error messages when you turn on your computer: CMOS CHECKSUM FAILURE, CMOS BATTERY STATE LOW, CMOS SYSTEM OPTIONS NOT SET and CMOS TIME AND DATE NOT SET. Another indicator of a low battery is a clock that, after being set, runs well while the computer is on, but shows the wrong time when the computer is turned on the following day (it is late).
Apr 21, 2009 | Dell (2336V) Motherboard
Finepix S9000 won't turn on with fully charged batteries
I have the exactly same problem on my E550, I also use AC adapter to test it, it works without any question, the conclusion I got focus on the circuit of E550, may be some parts was old enough that they need more Amp. to work, in other word, batteries won't provide enough juice to make them work correctly even you use new batteries. This is the issue regarding the quality of E550, Fujifilm should responsible for this, and we need sue fujifilm on this particular issue
Nov 07, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Fuji FinePix A600 Digital Camera Logo
103 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
