I just bought a 2007 accord and its having the same problem. Was there any resolution?
I have the same exact problem and all of my fuses are good and the wondow lock is not on
My 2007 Odessey has same problem and i found that i have no power to the three passenger fuses but driver side is fine. help!!!!!
I have the same issue on my 2007 Honda Accord. Driver's window works fine, all other three windows will not move. The front master lock button is not engaged. When I try to lower the disabled windows, I hear a clicking at whichever door I try, whether I use the window switch at the driver,s panel or at the door I am trying to lower the window on. I have searched the internet, but only find people with the issue and no solutions. Sounds like a widespread issue.
All passenger window not working, the driver side window works fine. Also hear a click sound on the corresponding passenger window when controlled from the driver side switches. when the window lock is switched on do not hear the click sound, so looks like the relay works, also have checked all the fuses for the passenger window and looks good. Wonder what could be wrong, looks like all the 3 passenger window stopped working at the same time. This looks like a common problem, as seen in the post, any pointer or suggestions will be really helpful
I have a 2005 accord coupe. My driver side regulator motor went out and when i replaced it, I found that I had issues similar to what you all are reporting. I found that the driver side master window switch had failed. I replaced it with what turned out to be an aftermarket replacement. Although replacing the window regulator and master switch worked for the driver side, I found that the passenger side window would only click when operated by either switch. I took my car to my good friend who works on Hondas and after checking the relays, fuses and wiring, he determined that the problem was the master window switch. I found and ordered a factory original replacement and installed it. While it was necessary to reprogram both the keys (which was easily done) the new, factory OEM switch solved all of my problems.
You have to remember that all window functions go through the driver side master window switch because you have control to lockout those functions through the master switch. If that switch does not work, you lose the continuity to the other windows.
I hope this helps everyone who is having this problem
I too have the same exact issue with my 2005 accord, just hear the click sound on the corresponding passenger window when pressed from the driver side switches, but no action. All of the passenger window went out of operation at the same time.
This is surely a common and widespread issue, and some one might be knowing a solution for that.. I some one has fixed it by any means kindly help us.
Try replacing the relay in the main fuse box
Any solution on the power window issue yet? My 2007 Accord has the same passenger and 2 rear windows not operating, clicking noise in door when i hit the button, passenger window stuck open 3-4 inches.
My 2005 honda accord has the same problem.
did you check to see if the window lock is on, on the drivers door panel?
