Question about Zanussi W1242W Front Load Washer
Will not spin dry at the end of the wash cycle
At the end of the cycle the water empties but will not spin dry, any thoughts?
  • Tinybryn Feb 04, 2008
    Hi - I have a similar issue. The wash cycle works until the spin cycle is supposed to start. The motor tries to spin, but cuts out after a few seconds. This is repeated until the spin cycle is complete after about 30 sec, when it normally takes around 5 minutes or so to complete the spin cycle. The programmer dial continues to rotate as expected.
How do i get to the brush of a kenmore elite to check it. ia m having the sme problem. My washer works until the spin cycle. i here the motor running extremely loud he button rotates but washer still does not spin.
Posted on Mar 09, 2008
  • Anonymous Mar 09, 2008
    How do i check the brush on a kenmore elite
  • 126 Answers
Check the brushes in the motor. This is a normal problem.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
Sep 15, 2015 | Washing Machines
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
My washing machine will not empty of water and this is preventing it from spinning.how do i empty the water via pump filter as i have no manual and it will not let me download one.please help!
This is could be caused from several issues. First I would try changing cycles on the timer to another spin cycle to see if that let the washer drain. Some times the timer malfunctions and doesn't allow the washer to spin. If this doesn't work and you can hear the motor running then you could have a broken belt or bad clutch or a wig wag (electric solenoids that operate the transmission.). The easiest way to empty the washer if it's located near a floor drain is to remove the drain hose from the drain and lay it on the floor near the drain. The water will run right out of the machine. If you not near a drain then you can use a Wet / Dry Shop Vac, remove the paper filter from inside the Shop Vac and then your ready to vacuum out the water. You will need to empty the vac several times.
Or you can use a garden hose and siphon the water out by place in one end in the washer and the other end outside or near a drain, You will need to **** on the end of the hose that's near the drain or outside. This will almost guarantee you a mouth full of laundry water so be careful if you try this.
Aug 05, 2010 | Washing Machines
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Kemore washing machine
The spin problem is related to the clutch and possibly the transmission. The transmission will leak oil which gets into the clutch causing it to slip. Reach underneath the machine and wipe your hand across the base of the transmission. If there is oil on your hand replace the transmission and clutch..
May 30, 2008 | Kenmore Washing Machines
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Zanussi W1242W Front Load Washer Logo
561 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
peter gittos
peter gittos
jimorris77
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
