Question about Canon PIXMA MP530 All-In-One InkJet Printer
Getting error 681 "more thn one magenta tank instaleld" on MP530
I get this when printing from PC or MAC via USB.
The tank is not empty, I tried powering dn/up, took the tank out and put it back in , nothing has helped so far...
Help !
Thanks \
Dan
  • 1 more comment
  • nik360 Feb 03, 2008
    I have the same problem with the Cyan tank.  This is very frustrating.  I have turned the printer on and off and I can't get it to accept the new cartridge.  Please help!
  • djiembefola Feb 04, 2008
    I researched this more online; by searching on error U071 - this turned up many, mant hits. Some suggested that there have been bad batches of the Canon cartridges where the built-in chip has failed. I replaced by cartridge (it was hardly empty) and sure enough, it now works fine. It makes sense then, that the cartridge was indeed faulty. It's certainly worth the 10-15$ to see it if solves the problem. Otherwise, the Canon MP530 has been a solid performer!
    Good luck
    Dan
  • nik360 May 11, 2010
    Thanks for the suggestion ctf1800, but that didn't get rid of my error (more than one cyan tank installed).  My Mac gives me error 1681 and the printer lcd says U071-check ink cartridge c.  Nothing is working.
    President:
  • 4,402 Answers
Install the Print Head and Ink Tanks MP530 / MP800 / MP800R / MP830
Install the Print Head and Ink Tanks Instructions to install the print head and ink tanks.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    Getting error 681
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
Follow the instructions below for Installing the Print Head and Installing the Ink Tanks.
  1. Raise the print head lock lever.
  2. Pull out the print head from its package, then remove the oraGetting error 681 "more thn one magenta tank insta - 03rq02454_02.jpgap from it.
    Caution: Do not touch the print head nozzles <1> , electrical contacts <2&gGetting error 681 "more thn one magenta tank insta - 03rq02454_03.jpgy ports <3>. Doing so may cause printing problems.
  3. Getting error 681 "more thn one magenta tank insta - 03rq02454_04.gif">Place the print head in the print head holder and lower the print head lock lever carefully until you hear a click.
Installing the Ink Getting error 681 "more thn one magenta tank insta - 05sj00141_05_en.jpg>
  1. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  2. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeGetting error 681 "more thn one magenta tank insta - 05sj00141_08_en.gif tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  3. Insert ink tanks into the print head.
    Getting error 681 "more thn one magenta tank insta - 05sj00141_09_en.jpgress the mark <PUSH> on the ink tank firmly until you hear a click.
  4. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    Note:
    Click for Ink Tank Lamp indications.
  5. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    N
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Posted on Jan 22, 2008
  • Cary Farah
    Cary Farah Feb 04, 2008
    please mark the solution as fixya!
U052
To try and resolve the U052 error on your PIXMA MP550, please remove the ink tanks and print head from the printer, then reseat them. If you still experience the same issue, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. If the issue is still unresolved, unfortunately, the printer will require servicing to resolve the issue.
You can contact Cannon here: Canon Contact Us
This information originally from: My printer Canon MP530 stopped working with an Canon Forum (also has a walk through for removing the printer head and ink cartridges.)
Just so you know, the 530 and 550 are the same machine, except the 550 has a few small improvements.
Mar 31, 2014 | ErrorExpert
Tip
Samsung ML-2525W printer & Mac OS X 10.6
I think there are 6 ways (at least?) to connect this printer:
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
on Apr 25, 2010 | Office Equipment & Supplies
Cannon mp530 won't print magenta, changed
Hi. That happens sometimes with generic cartridge. It seem that print head is defective.
Feb 18, 2018 | Canon PIXMA MP530 All-In-One InkJet...
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Misreads ink tanks: says full ones are empty and there are 2 cyans, etc.
I had the same problem -- error message saying two cyan print tanks installed. Nothing helped (including disconnecting power cord). Then found I had an older cyan print tank still in its pack on hand, Installed that. No further problems. Assume this means print tank giving error is part of a faulty batch so am returning to retailer for refund from Canon.
Oct 24, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
291 people viewed this question
old marine
old marine
