Question about Philips Magnavox 27MS343S 27" TV
Magnavox 15" LCD TV
My TV is approx. 2 years old and is described as LCD. My question is when all signals go to digital next February, will my TV perform in HD since we have Comcast cable connection? My other TV's have 2 different connections--coax and HD...the LCD set only has coax.
    Problem Solver:
  • 9 Answers
If the LCD only has coax, it will never display a HD picture quality. However, the Comcast HD Box will still display a picture using the coax connection. So, you could watch any HD channel, but the picture quality will not be high definition.
Posted on Jan 27, 2008
  • 281 Answers
They will definitely have adaptors for your tv.
Posted on Jan 24, 2008
37 INCH LCD MAGNAVOX TV WILL NOT TURN ON. MUST BE
This problems,very common in LCD tv,after the tv was in used about a year or two.The new technalogy LCD tv don't handle heat very well,not like the old CRT Tube Tvs.The power supply board tend to have bad capacitors componnents leakage,that bulges up it top or puff up gases escape,that why it take times or couples pushes to the power botton to turn the tv on.U know basic electronic's,and have soldering tools and solders?Take the tv aparts,check for these bad capacitors,that bulges,puff up in the power supply board and replaced them,than ur power will work normal again.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 29, 2010 | Philips Magnavox 51MP392H Rear Projection...
Magnavox LCD HDTV starts on its own since last few months and sometimes it changes channel on its own. This problem happens intermittently and really apprecaite fix for this. This TV is 15 months old.
it either needs new front switch panel or new signal module, turn the tv on and disconnect the front switch board if it quits doing things on it's own you need a new front switch panel, if it still does functions on it's own you need a new signal board.
Sep 08, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
I have an older magnavox 25 inch color tv, about 8 years old. Gave it to my daughter for college and now cant ge the channels to auto program for cable tv
If the cable provider is sending digital signals a TV that old will not be able to receive them. If they are not digital signals they may be encrypted. You may need a cable box from the cable provider or use a DTV box to get free over-the-air digital broadcast signals.
Aug 22, 2009 | Televison & Video
I have a Magnavox projection screen tv. The tv
Will you have got a lot of years on this unit. There could be a lot of things wrong here are some things to check.
SMD capacitor 2009 on Small Signal Board
Check fuse on SSB location 1003
Check resistor 3306 15 ohm surface mount
audio output IC 7700 on the Small Signal Module
May 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
I PURCHASED A MAGNAVOX TB110MW9 CONVERTER BOX FROM WALMART. I HOOKED IT UP. IT SCANNED THE CHANNELS BUT IT KEEP SAYING NO SIGNAL.
I have a Magnavox TB110MW9A converter box that has worked fine for the last 8 months. Now you turn it on, the light blinks 31 times, stays on and there's nothing on the screen! The remote does nothing. (yes, I put new batteries in)
Jan 25, 2009 | Televison & Video
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Is my trutech lcd flat panel digital?
LCD monitors are compatible with Digital Video Input(DVI) and have the slot for it. Hence you can use it with a Digital signal source.
Regards,
Sai.
Jul 01, 2008 | Televison & Video
Magnavox 81 cm LCD TV Model No. MLCD32
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Jun 04, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Get Direct TV Remote to TOTALLY work with Magnavox TV
My TV remote has a slide-switch at the side to switch between the TV, DVD or VCR. I don't know if yours has one, if so, switch it to TV. It also has a button to switch between Analogue, Digital and External, so make sure if you have a button like this that it's switched to the right input.
Jan 28, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 37" LCD HD TV 3 years old
You may need to replace the Small Signal Board of your tv.
Nov 25, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Magnavox 27MS343S 27" TV Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
