Question about Canon CanoScan 8000F Flatbed Scanner
Scanning sheet music
I need to scan sheet music,300DPI,PDF, at least 300dpi in TIFF black & white. The scans keep comming all broken up & unreadable. Any ideas? Thanks, Gail
    Problem Solver:
  • 12 Answers
Scan all pages with GrayScal Single Page JPEG and then convert them to Multipage PDF.
Posted on Apr 03, 2008
FS-3140 memory full when scanning
change scan defaults to monochrome, pdf, and 300dpi or lower resolution in command center.
Feb 18, 2013 | Kyocera Copystar FS 3140MFP/DP copier
Scanning is very light
- lower your scanning resolution, 200dpi or 300dpi should be enough
- if you are scanning text, use black and white color mode
- if problem persists, call HP TECH SUPPORT and ask them for the Fix Scan Utility
Jun 21, 2010 | HP Laserjet M2727nf Multifunction Printer
How to enlarge scanned photo.
Set your scanner to scan at 600dpi.  That will give you a 8x12 image at 300dpi (print quality- your image never needs to be more than 300dpi).
Then use your favourite image editor to crop the image to 8x10.  If you don't have a favourite image editor, XNView (free) will do it:
-Open the image in XNView
-Right click on the image, select "Set Selection Ratio --> 5:4"
-With your left mouse button, drag a square on the image...this will automatically scale so it chops the unwanted 2" off
-When the square is selecting the bit you want to keep, select "Edit --> Crop"
-Then we need to change the image from 600dpi to 300 dpi:
-Select "Image --> Resize"
-Uncheck the "Resample" and "Keep print size"
-"Keep ratio" should be checked
-Change the 600 in the "Units" box to 300; the setting unit should be "Pixels per Inch"
Mar 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
Mar 06, 2009 | Xerox CopyCentre C123 Copier
Scan views fine; prints fuzzy
Try to change the dpi to the maximum, maybe 600 dpi. This will make the picture more defined.
Nov 19, 2008 | Brother MFC-7820N Printer
Trying to scan document on HP Deskjet F4200 all in one series. When scanning small document from TIFF Image this is scanning through as 25.5 MB so I am unable to send this as an attachement to an email as...
Try lowering your scan resolution settings. Magazine quality is 300dpi. If you don't want to lose too much quality, open the file is a image editor and crop only the area you wish to send.
Nov 06, 2008 | HP Computers & Internet
Can't scan to email for a Canon ImagineRunner C2550
You need to set the scan settings in copier settings 200dpi 300dpi color or black and white....
Jun 19, 2008 | Canon CLC 1120 Color Copier
Scanning B+W shows dots
Don't use Descreen. That is for scanning things such as Magazines that, when looked at very close, appears to have a lot of little dots that can cause a moire pattern when scanned.
Apr 06, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scanning problems
The scanner will only do what it is made to do thats its biggest.
Apr 20, 2007 | Minolta Dimage Scan Elite II Film Scanner
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Canon CanoScan 8000F Flatbed Scanner Logo
133 people viewed this question
old marine
old marine
