Question about KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid KGRA806PSS
Oven Door Locked after Clean cycle and panel is blank
  • cdur Jul 01, 2008
    I have the same problem Oven Door Locked after Clean cycle and panel is blank
    President:
  • 1,314 Answers
Try pressing stop/clear press and hold timer for 5 seconds after making sure there is piower to the range
Posted on Jan 22, 2008
6ya staff
SOURCE:
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Kitchenaid KGSS907 oven door locked after self clean mode, what I must do?
Thermostat at the back/rear might have blown.
Is the oven still working?
Then the door actuator motor may have failed.
Jan 27, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid KGSS907 oven door locked while in self clean mode
It locks so you dont open it during the cleaning cycle. It gets very hot so it burns everything stuck fast to a crisp. after cycle is over and temp drops it will unlock. dont worry about a small amount of fire as long as it dosent get too big it should be fine. Might make alot of smoke though.
Dec 27, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
The oven door cannot open. The self cleaning cycle was not completed because the display window went blank and as a result the oven door remained locked. This occured during the Christmas season and...
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 24, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Door locked: display panel not lit.
Unplug the appliance and the next day it will work again. Do not use the self clean cycle or I will have to spank you! Did you not know that 900 degrees for 3 hours can harm delicate expensive electronics. Get some easy off and clean that oven or get ready to spend some serious dough on fixing this puppy down the line.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
Jan 21, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven shut down
IT IS THERMOSTAT IN BACK PANEL ABOUT A 48.00 PIECETWO CLIP WIRES AND TWO SCREWS IT IS NOT IN TOP OF STOVE IT IS IN FLAT ACCESS PANEL BELOW
Sep 21, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
139 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Jay B
Level 1 Expert
Colin Stickland
Colin Stickland
ittco
Level 1 Expert
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
