Question about ASUS P5GD1-VM Motherboard
ASUS P5GD1 I installed 4 identical strips of transend 1GB DDR , the computer only see's 2,75GB.
You will need a 64bit OS to be able to address all 4GB. Win32 tops out at 3GB. But, I would think the BIOS would recognize the 4GB. I have one of these also and have done the same thing. So, you could try the 64 bit version of XP or go with a 64 bit version of Vista. Pay attention to the Vista packs though, not all are 64 bit. OEM versions will be one or the other, boxed full version of Ultimate contains both, not sure about the upgrade or boxed Home/Office versions.
Posted on Feb 01, 2008
    Genius:
  • 1,067 Answers
Well sum mobos well if u have xp home it will only read that far vista will go to 16 gb
Posted on Jan 22, 2008
6ya staff
SOURCE:
Chan the
Hi, download drivers and a manual here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5GD1-VM&p=1&s=22
Please select your operating system.
Select driver or manual and click on global for download.
The file needs to be unziped before installation.
Aug 26, 2011 | ASUS P5GD1-VM Intel915G LGA775 DDR VGA...
HP Pavilion Media Center PC not detecting memory in slots 3 & 4.All memory works in slots 1 &2.Memory is all the same.
Info from the manual:
Memory configurations
You can install 128 MB, 256 MB, 512 MB, and 1GB DDR SDRAM DIMMs into the DIMM sockets using the memory configurations in this section.
• Install only identical (the same type and size) DDR DIMM pairs
using the recommended configurations.
• Make sure that the memory frequency matches the CPU FSB
(Front Side Bus). Refer to the Memory frequency/CPU FSB
synchronization table on the next page.
• This motherboard does not support double-sided 16-bit DDR DIMMs.
• Do not create a three-DIMM configuration in dual-channel mode. The
third DIMM is ignored in the dual-channel operation.
Recommended memory configurations
Memory frequency/CPU FSB synchronization
* Use only identical DDR DIMM pairs.
Sockets
Mode DIMM1 DIMM2 DIMM3 DIMM4
Single-channel (1) Installed - - -
(2) - Installed - -
(3) - - Installed -
(4) - - - Installed
Dual-channel* (1) Installed - Installed -
(2) - Installed - Installed
(3) Installed Installed Installed Installed
CPU FSB DDR DIMM Type Memory Frequency
800 MHz PC3200 400 MHz
533 MHz PC3200/PC2700 400/333 MHz
Feb 18, 2011 | ASUS PTGD-LA Motherboard
What is the newest INTEL processor for an ASUS P5GD1-VM 915G motherboard.?
It depends on your chipset..if it is the Intel 915G chipset you can only use a Pentium4 with up to 3.3 GHZ
Dec 26, 2010 | Intel ASUS P5GD1-VM 915G LGA775 DDR 400...
Vga for P5GD1
No, your motherboard lacks the PCI-x16 interface slot to be able to facilitate this card.
Jul 28, 2010 | ASUS P5GD1 Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
I have an asus k8v-mx motherboard running only 512 mb of ram what type of ram would suit this mother board and could i fit a 1 x 2mb ram instead of 2 x 1mb?
Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Aug 05, 2009 | ASUS K8V-MX Motherboard
Upgrade question on ASUS P5GD1-VM/S mobo
According to the manufacturer it will support P4/celeron 3.6Gz+ procesors. And memory should be Dual channel memory architecture 4 x 184-pin DIMM sockets support max. 4GB DDR 400/333 non-ECC memory. Hope this gets you up and running.
Jan 31, 2009 | ASUS P5GD1-VM Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
ASUS P5GD1-VM Motherboard Logo
130 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
