my logitech harmony 890 remote is about 4 yrs old and some of the buttons are worn. Also, the volume up button is considerably less sensitive than other buttons. Are there repairs for either or both?
There seems to be an issue with the Harmony 880/890 where, after a time, certain buttons that are used more often become unresponsive (though 4 years is not a bad run!) They either need to be pressed very firmly (and sometimes held down for a few seconds), or they stop working entirely. This is probably due to the wearing out of the metallic bubble button that is beneath the film adhesive of the circuit board. If this has happened, the repair can be tricky. In most cases if only one or two buttons are the problem, you may want to try the 're-mapping' strategy as described below. Remember, the beauty of this remote is that you can create 'soft' keys using the LCD screen and re-map almost any key you like. Here is a link to a good post on the Logitech forum which describes how to test the buttons and re-map them. Good Luck!
I am getting an error on my screen I can hear the station but the TV says Componenet 2 No signal how...
(More)(More)
I am getting an error on my screen I can hear the station but the TV says Componenet 2 No signal how do I correct it?
Since installing my Harmony 890. My TV has started randomly changing channels by itself. Why is this...
(More)(More)
Since installing my Harmony 890. My TV has started randomly changing channels by itself. Why is this ??
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
I have an 890, been fine since I got it months ago. This morning all was fine, then all of a sudden...
(More)(More)
I have an 890, been fine since I got it months ago. This morning all was fine, then all of a sudden the IR extender stopped working. All the IR devices are fine, all the extended devices don't work. I tried: -Updated the remote and extender firmware. Both took the Firmware updates fine. -But when I do the Update Remote function Im asked to hook up the extender first and I always get the following messasge. - Step failed Updating region RF : RF5101 - The information was not sent. Check your USB cable and try again. If the problem persists, contact customer service. Step 1 of 4 Downloading settings 12% Complete -I bought a second rf-extender and it updated the firmware automatically and then had the same failure above. I also had the virus protection and the firewall turned off. None of the above worked so far...
Posted. Thank You!
my 890 is no longer working correctly. It won't turn on the power for my reciever and only works...
(More)(More)
my 890 is no longer working correctly. It won't turn on the power for my reciever and only works partially in turning on/off my TV
Posted. Thank You!
We can't change channels using the numbered keys on the device. This is the result of the cable ...
(More)(More)
We can't change channels using the numbered keys on the device. This is the result of the cable leading to our home having been repaired.
Posted. Thank You!
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
