When the printer runs out of ink, the head moves accross as normal to let me change the ink, but while I am trying to change the ink cartridge, the head starts moving spontaneouly and jams with the ink cartridge still half out. - canon i9950
  • shop22ph Jan 23, 2008
    turning the printer off by pulling out the power cable solves this, but I have to start up the print job again. Turning off with the power button moves the head back to inaccessible position. Would still like to know if anyone has solved this problem without having to pull out the power cable!
    Scholar:
  • 64 Answers
Printers can do strange things, they are none the less mechanical in some respects. Whilst in operational mode, they can start up and resume a print job that has been spooling for hours ( usually due to network issues or overloads ) but getting back to your problem, i would suggest turning the unit off when the head is in the correct spot and insert the cartridge.
Additional info ( not required reading )
I have one theory is that most manufacturers are re-using older software drivers and updating where needed, and aren't getting away from the step by step type program enough. If a printer misses a step for whatever reason, it will continue to behave strangely until the unit has been put back in sync. Please someone tell me why is this so ? and if i am wrong, why does my printer fire up in the middle of the night, spit out 10 blank pages for no apparent reason ?
Posted on Jan 23, 2008
I have forgotten how to move the ink cartridges into a position where they can be changed.
Turn on the printer. Open the top of the printer to expose the ink cartridge compartment. Hit the "Stop" button. This will cause the printer head to move so that one of the two ink cartridges move above the "No Ink" icon. Hit the "Stop" button again. It will move the other ink cartridge above the "No Ink" icon if it needs to be replaced. The printer head will move to the original position to the right.
Aug 29, 2011 | Epson Stylus CX7400 AllinOne InkJet...
Ink holder will not stop in middle to change ink
Hi, normally when changing ink cartridge, once you open the cover the printer head move from home to the center of the printer and halted,if in case this not happen something wrong with the sensor, if the printer move from home to center just pull off the power cord to stop the printer at the middle or nearly at the middle just to remove the cartridge and replace it. Upon replacing the ink cartridge, just power on the printer and it will return home to its position.
Jun 17, 2011 | Office Equipment & Supplies
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
CANNOT CHANGE THE INK CARTRIDGE
I've run across a few stubborn printers that do this. Sometimes it doesn't recognize the button push etc. The easiest way to do this is to unplug the printer and manually move the print head to the middle and then replace the cartridges. It will be stiff but shouldn;t take too much force to move it. When you turn plug it in after changeing the carts then it will zero itself again and work normally.
Jun 01, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
The middle of the page won`t print and the colors look faded...the ink levels are fine... thanks
Look for a utility program which will run a function called 'head cleaning'. When a printer hasn't been used for a while or you have bought sub-standard ink cartridges, the ink becomes dry and thick. This can block the nozzles of the cartridge and stop it from functioning correctly.
If you can't find the utility for your printer, remove the cartridges and using a lint-free cloth soaked in alcohol/strong solvent wipe accross the head to clean.
Jul 07, 2009 | Office Equipment & Supplies
Carriage cycles normally but no ink on paper.(Stylus color 880)
Turn off printer. Open Case. Move head carriage to parking position. Do suction from outlet pipe of head cleaning mechanic. It's for checking head. is there ink out? If printer not used for long time, may be ink inside head dried. Utility screen just show estimated not actually. If head clog, and do head cleaning more 5 times, screen show ink nearly out, but actually ink tank nearly full.
Jun 28, 2009 | Epson Stylus Color 760 InkJet Printer
I need to replace the color ink in my Epson stylus color 740
To force a Cartridge change press and hold down the Paper feed (load eject) button for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Before changing the carts it is recommended that you run the head cleaning utility.
When you have poor print quality and have tried the head cleaning utility it is recommended that you replace the cartridges. Ift the red lights aren't on to indicate the ink is out you need to force the cartridges into a change position. To do this press and hold down the paper feed button (load eject) for over 5 seconds and the cartridges will move into a change position. Please note: if the cartridges move to a position where only the Black cartridge can be changed pressing the Paper feed button once will move the head so that the colour can be changed.
Regardds
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jan 04, 2009 | Epson Stylus Color 740 InkJet Printer
Seem unable to get my ink cartridge holder in middle position to insert new cartridge. have tried 2 TR27 copy cartridges from ABITECH Nottingham but both made the error light flash ! Printer id EPSON...
I cannot remember if the Status Monitor (SM) of the 810 has a "change cartridge" facility, but it's easy to check. Right click the printer icon in the bottom right-hand corner of the screen and select printer settings. Then click the maintenance tab - is "change cartridge" one of the options? If so, use it. If it isn't you can download the SSC utility from
http://www.ssclg.com/epsone.shtml
and use this to move the cartridge to the cartridge change position - don't forget to use it to do an ink charge cycle after you have replaced the cartridge.
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Sep 15, 2008 | Epson Stylus Color 460 InkJet Printer
Changing ink cartridge
Here is how to get the ink cartridges to move to the changing position on the R320.
1. Press the paper jam/ink button on the printer control panel.
2. A menu comes up. 1st item is ink cartridge replacement. Press
OK button.
3. Another menu with ink cartridge replacement. Press OK button.
4. Thats it, ink cartridges move to the changing position. Change your cartridge as you normally would and follow prompts on screen to finish process.
Hope this helps.
Aug 05, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson c60 printer
Common problem with Epson Printers.
Either the print head is clogged, or the tube that goes from the pump to the printhead fell off.
Open the printer cover so that the ink cartridges are in open view and then UNPLUG THE PRINTER" so that the ink cartridges wont go back to home position. (If there is a change INK cartridge button, then press that then uplug the printer when the cartridge stops moving.)
You can try to clean the print head by folding up a couple paper towels, then saturate it with windex with amonia. Place it under the print head assembly and manually move the print head assembly over the paper towel back and forth to clean the bottom of the print head assembly. You should start seeing ink on the paper towel.
After cleaning, run the cleaning program that Epson has, and try it out.
If it still doesn't work, then you might have to repeat this a couple more times.
If it still doesn't work, then it might be time to get a new printer.
Hope this info helps.
Good luck.
Mac
Feb 07, 2008 | Office Equipment & Supplies
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
