Question about JustCom jc-102cp 2-port KVM Switch
KVM 2 port switch not working
I switched keyborads. I had a Dell keyboard now i have a logitech keyboard and my KVM 2-port JUSTCOM switch does not work>
  • 4 Answers
SOURCE: Belkin (F1DK102P) 2-port KVM Switch freezes
switch connections from pc1 to pc2 and boot up pc 2 first make sure everything works and then boot up pc 1 wait 2-3min then tre the switch
Posted on Dec 20, 2007
Hot-Key Commands
You can change ports on the switchthrough the simple Hot-Key commands using the "SCROLL LOCK" key and the UP and DOWN arrow keys.
1. To invoke the Hot-Key mode, Press the "SCROLL LOCK" key twice within two seconds.
2. Press the UP or DOWN arrow keys to switch to the previous or next port respectively.
Alternatively you can directly switch the KVM focus to any computer by entering the switch port number. Ex. press "SCROLL LOCK" "SCROLL LOCK" 2 and the computer on port two will be selected.
Posted on Jun 26, 2008
SOURCE: Compaq 8 Ports KVM
Try PrtSc port # ENTER
Posted on Jul 24, 2008
SOURCE: Keyboard Sequence for Compaq 4-Port KVM Switch (Series 4115)
Mine uses the "Print Screen" for the menu & "Print Screen" + 1, 2, 3, or 4 for direct access.
Posted on Aug 20, 2009
SOURCE: Justcom kvm switch with audio?
Scroll Lock - Scroll Lock - F1 for first PC
Scroll Lock - Scroll Lock - F2 for second PC
Posted on Jan 13, 2010
  • 353 Answers
SOURCE: i just bought a 2-port kvm switch model no.
You can conveniently change ports on the Switch through a keyboard command
sequence using the “SCROLL LOCK” key and up and down arrow keys. To send
commands to the Switch, press the “SCROLL LOCK” key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
Posted on Apr 16, 2010
0 characters
1 Points
I have a d-link kvm-121 connected with 2 pc desktop when both pc is on 1 of the pc will see the shadow of another pc and then i tried to plug off the vga cable of one of the pc there are no more shadow....
The D-Link 2-port PS/2 KVM Switch with Audio Support(KVM-121) allows you to .... docking station and a Dell desktop, using a logitech PS/2 mouse and keyboard. ... as it easily allows me to connect another computer when I'm troubleshooting problems. ... See the nine (9) Hot Keys on page 9 of the superbly written and ... › ... › Cables & InterconnectsKVM Switches - Cached - Similar
Jun 30, 2010 | D-Link KVM-121 2-port KVM Switch
I have a justcom jc102cpa kvm switch and I need the hotkeys
KVM <====> Keyboard, Video, Mouse
Note that 'AUDIO' is not part of the "KVM" switching feature.
Dec 11, 2009 | JustCom JC-102CPA KVM Switch
Jc102cp lost manual what is the key combination to switch between computers
Scroll Lock / Scroll Lock / Up Arrow switches to next (2nd) computer. Also, Down Arrow.
Jul 12, 2009 | JustCom jc-102cp 2-port KVM Switch
Keybrd quits working on laptop after ctl-alt_del to reach login
Repeating keys? This is a common problem for KVM switches if you go beyond the devices' capability. As you can see, GCS62 is a PS/2 KVM switch and it was designed to work only using a regular PS/2 keyboard.
This KVM switch does not support PS/2 to USB adapter. It might work but it's not guaranteed to work correctly. This does not work properly if you have a docking station for the laptop. It might work for couple of months then it would stop.
You smay isolate the problem by following the steps below:
1. Connect the keyboard directly to the computer to see if you will get the same problem.
2. Power cycle the KVM switch by disconnecting it from the computers and leave it unplugged for a minute or two.
3. Avoid using hybrid connection (PS/2 converted to USB) only for testing purposes.
4. If that work, then you know the answer is that this KVM only designed an work correctly with native PS/2 connection.
Feb 22, 2009 | IOGear MiniView GCS62 2-port KVM Switch
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
What's the deal?
Is it possible that there is a problem with the button? Try wiping them down with a damp paper towel or blasting it with canned air. Also, most of the time KVM's have a keyboard shortcut that will change the input also, perhaps give that a try.
Jan 07, 2007 | JustCom JC-102CUA (JC102CUA) KVM Switch
JustCom jc-102cp 2-port KVM Switch Logo
121 people viewed this question
Top JustCom KVM Switches Experts
Peter Parker
Peter Parker
Are you a JustCom KVM Switch Expert? Answer questions, earn points and help others
