Back to:
Tags:
Freezers
Generic problem for all Freezers
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT...
posted by AVYY on Jan 22, 2008
TRICITY BENDIX-FRIDGE/FREEZER. LIGHT BULB FUSED AND FRIDGE STOPPED WORKING, I REPLACED BULB BUT FRIDGESTILL NOT WORKING. THE FREEZER SECTION IS WORKING FINE. ANY IDEAS GUYS?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 26, 2008
Helpful (85)
bobotfel
Rank:Wiz Wiz
Rating: 83%, 162 votes
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Rating Locked! (?) AVYY has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING:
I don't want to Accept this solution
Can you Help with these Freezers problems?
Frigidaire Freezer Refrigeration White...
I have a GE side by side (approximately 6 years old). I...
Freezers
need a key for a kenmore chest freezer,
Frigidaire 14 cu. ft. / 396 liter Upright...
My Kenmore Elite upright freezer does not get real cold;...
Freezers
hi, i heard a banging noise coming from my litchen last...
Freezers
switch at bottom of freezer when turned on buzzes...
Loading problems.
Repair Service
Find Freezer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
