Question about Brother MFC-3240C All-In-One InkJet Printer
Will not print
Printer says unable to print.
see troubleshooting and routine maintenance chapter in user guide
problem is i have lost my user guide please help
kind regards k .cleckner
Brother MFC-3240C: Printer message says "Unable to print". I tried the solution in the User's Guide with no success. Fax function is not enabled (by choice). I pulled the power plug and waited 5-10 minutes, plugged it back in, with no success. Help!
ek
  • 1 more comment
  • latia Jan 28, 2008
    will not print//solution from manual doesn't work/checked for jammed paper/unplugged power and restarted.
  • pavalam Feb 14, 2008
    Message on printer says:
    Check the Troubleshooting and Routine Maintenance Chapter in User's Guide
    Can't find my user's guide. Have powered off and on but makes no difference.
  • Anonymous Nov 01, 2008
    The printer doesn't work and when I unplugged and plugged again, there appears PLEASE WAIT and suddenly I can read UNABLE TO PRINT SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USER'S GUIDE.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
If you lose your manual, you can view the online version by following this procedure:
1. If your computer does not have an installed PDF viewer already, install one. Two popular ones are Adobe Reader and Foxit Reader.
2. Click the link below for the manual that you wish to view. Three different manuals are available:
To troubleshoot a problem or perform routine maintenance, open Users Manual - English and see Chapter 12, Troubleshooting and routine maintenance, which begins on page 145 of that file.
Posted on Jul 21, 2008
I have the same error message “Check the Troubleshooting and Routine Maintenance Chapter in User's Guide" I called customer service for "BROTHER 1-800-284-4329 USA; 1-877-BROTHER for CANADA. The Tech’s and I performed a series of diagnostic test, via the phone but were unable to solve the problem... Brother seem to believe that I have a defected printer head, Brother referred me to a local authorize service agent for Brother. I do have my User's Guide and there is no additional information that I was able to use to resolve this problem. HOW EVER, I am able to get the machine to print by opening the cover and close it as if I had installed ink, or removed a paper jam “SIMPLY OPEN AND CLOSE THE COVER”. I also vacuumed and blew the insides and the outside buttons of the machine with forced air from my vacuum, after all that I still have the same problem. My solution...buy a new machine mine is 32 months old and I probably have ran 15k or more print, fax, and copy jobs.
Some times we need to know when to move on, TIME IS MONEY AND TIME WASTED IS UN-REFUNDABLE.
GOOD LUCK
TG/Ks
Posted on Apr 20, 2008
2 Suggested Answers
6ya staff
SOURCE:
Mix-it-up
Mix-it-up
  • 832 Answers
SOURCE: will not print
What 2 digit error code does the machine display, too?
Posted on May 12, 2008
THE LCD SCREEN SAYS PRINT UNABLE 50 AND SEE TROUBLESHOOTING AND ROUTINE MAINTENANCE CHAPTER IN USERS GUIDE.
Read the users guide and do what they say in the Troubleshooting and Routine Maintence Chapter for the "Print Unable 50" error message.
Mar 29, 2011 | Office Equipment & Supplies
Unable to clean see troubleshooting and routine maintenance chapter in user's guide
unable to init. see troubleshooting and routine maintenance chapter in user's guide - printer: DCP- 115c
Jan 30, 2011 | Brother Multi-Function Center® MFC-215C...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . [email protected]
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Will not print
www.brother.com has those user guides by model number..
Jul 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
May 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Will not print
You have a major error, probally head stuffed error 41, to find out your error press menu starte and up 4 times, this may show error if not then input 82 set, error will display.
Post back if need more info
S.
Jan 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
unable to print, See troubleshooting and general maintenance in User's Guide, however, I do not have a User's Guide! What to do?
Nov 14, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-3240C All-In-One InkJet Printer Logo
569 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
