Question about GE 25942GE2 Cordless Phone System
Registering phones I have charged the batteries for over 16 hours. Both hand sets say "Please register," but replacing the handsets on the base does not work. Phone says "unavailable" when trying to use.
  • 3 Answers
I have after many hours found the solution. (Well one that worked for me). I have a Uniden Elite 8855 + 8805 additional handsets. What you have to do is:
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
Posted on Feb 14, 2008
Uniden D3098S I have 2 register hand sets #1 and #2 I have a 3rd one having trouble registerting it to the base iam 2 feet away from the base unit it says check base power & out of range
Registering a Handset
If you see a "not registered" message on a handset, you must register it to a base before using it.
1. On the base, open the menu and select "Register Handset"
2. On the handset, press and hold POUND (#) until the handset display says "Handset Registering" (about 2 seconds).
3. Wait until the handset display says "Registration Complete" (about 30 seconds), then pick up the handset and press eND/CleaR.
# If you don't hear a dial tone or the display says "Registration Failed" charge the battery completely, then try again.
May 12, 2016 | Uniden Lands Phones
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
handset must be de-registered from its original
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
0. Start by taking off the battery compartment cover.
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??",
press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY
(this is why the cover was off)
9. Wait ~30 seconds, re-connect the battery &
replace the cover
10. display reads "Not Registered"
( II.) To clear the base of all handset registrations
( if needed, else skip ahead to ( III ). )
1. press [Find Handset] on the base and hold
past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink. 2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration ===============================
( III.) To register each handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #x" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a
few hours and try the registration ( III ) again.
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
1.
Register Accy.
2.
On the handset, press and hold #/DND
Handset Registering (about 2 seconds).
3.
Registration Complete (about 30 seconds),
then pick up the handset.
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
My phone displays out of range how to correct
This sounds like a registration problem. Try
de-registering the handset(s) and re-registering
to your base.
NOTE: the CS6429 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Oct 02, 2014 | Vtech Accessory Handset with Caller ID for...
My brand new phone is not getting fully charged. I have put it on charge for even more than 8 hours. The charge bar is still showing very low sign. Additionally it is not getting registered despite...
The set could have been on shelf for a long period and so it is possible that the battery has developed back emf which makes it difficult to charge to the full level.
Also sometimes the set fails to lock on due to the same reason and also if the threshold of voltage does not come up.
Discharge the battery after it has charged a bit and charge again.Allow the battery to be put for charging for over 24 hours. If there is no registering then you must try and see if the warranty on the new phone is applicable as the base and handset could be out of sync..
Feb 05, 2011 | Panasonic KX TG4021 Cordless Phone
I replaced the battery and fully charged it. The display says "connecting" then, "place handset in Base to register". It still does not work
This is because when you replaced the battery it might have reseted thehand set.Now again you must register your hand set to the base.
The registering procedure will be given in your user guide of your phone.
If you don't have an user guide please tell us the model number of your phone so that we can assist you better.
Thanx
Jul 27, 2010 | Uniden Cordless Phone
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
Tried to reregistering
Hi
Please try the following procedure:
To register your handset to base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 27, 2009 | Uniden Cordless Phone
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
Feb 10, 2009 | Uniden TRU9480 Cordless Telephone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
GE 25942GE2 Cordless Phone System Logo
332 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
