Question about Minolta magicolor 7300 Laser Printer
Minolta 7300 - tearing through consumables
I have a minolta 7300, with only 7324 copies on it
it should go through heads in approx 32,500 & they're asking to be replaced already, waste cartridge should fill approx once per 7000 prints, & has already been filled 6times
any suggestions?
rob
artwork@apple1art.com
  • 34 Answers
I've had the same issue with this printer. Are you using Minolta own brand cartridges? You should be.
It sounds like it is wasting a lot of toner. You'll need an engineer to check the drum mechanism.
Posted on Aug 11, 2009
Konica Minolta 7300 fixation error
replace the fuser
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 17, 2014 | Konica Minolta Office Equipment & Supplies
My printer only prints black
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
May 08, 2013 | Konica Minolta MAGICOLOR 7300EN LASERPR...
Trans belt low msg??
You can still use it but will need a new transfer belt soo which is a consumable product.
Apr 28, 2013 | Minolta magicolor 7300 EN Laser Printer
All toner cart's replaced, new toner heads about 1000 pages ago, new waste tray. Printing colors ok but anything with black in it comes out blotchy or faded.
(1) If it takes developer as well as toner you will need to change the black developer.
(2) Also check the voltage is correct
(3) check that the toner path is not blocked
lets know how you get on
Feb 23, 2010 | Minolta magicolor 7300 Laser Printer
HALLO. >I HAVE GOT A KONICA MINOLTA C300.THAT IS MAKING LIGHT COPIES EVEN WHEN PRINTING FROM MEMORY A DEMO PAGE. PLS! ASSIST WITH SOLUTION TO THIS PROBLEM?
Have you check, the image units, for is the light copies a b/w issue or a color issue? have you check the consumables does the transfer belt or fuser unit need replacement. are image units OEM or third parties?
Aug 17, 2009 | Konica Minolta Office Equipment & Supplies
The ADF Konica Minolta causes paper jamp or may bend 1 corner of
check there are two locking claw for uper cover of adf one is broken check and replace if necessary
Apr 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta magicolor 7300 message "print unit
Print head is passed its life which is the LASER get a new one.
Aug 05, 2008 | Minolta Office Equipment & Supplies
Konica Minolta Problem
Check all your paper tray make sure all side guide are set properly to the size of your paper. Check the front on the right side there is a paper size nob and set to the size of the paper in the tray next to it. A sheet 8.5x11 paper on four side edge of the paper make an arrows marking and place it to platen glass and make copies and make sure to choose which paper tray you are using. The marking all should be in all four corner of the copies. if not recheck the paper tray side guide. if this did not work. what ever paper tray is off registration, removed the the paper and lift the pressure plate or lift plate there is two screws to loosen to adjust rear and front paper side guide.
HH
Sep 26, 2007 | Konica Minolta MAGICOLOR 7300EN LASERPR...
Minolta magicolor 7300 Laser Printer Logo
79 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
