Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
Green shadows in dark scenes
Hello, I have an LG RZ 42PX11 four years old. Recently in dark scenes, it shows a lot of green/gray shadows of pixels located on the edges of the shapes that have very similar colors (as an example, on the faces, where several tones of pink are closer). The problem almost disappear in light scenes or increasing a lot the brightness (where black color almost become light grey). Any Suggestions? Thanks a lot.
  • Anonymous Dec 26, 2008
    The color is dark and a lot of green. No matter how much we change the colors it does not seem to help. There is a auto color buttom on off and it will not let us change to on. It skips down.
  • 221 Answers
You should contact Service Center to resolve this issue.
Posted on Jun 18, 2008
I had similar problem on my Samsung PS50A656 here in Europe...I could see it only when playing from my notebook from USA. The settings were 1080/60hz as my notebook`s monitor supports only 60hz. Although the TV was able to play that, I saw those clouds of green as you describe. I switched the notebook monitor completely to TV and than changed the settings to 1080/50hz. The green clouds are gone...
But now when I check the Info Screen on TV it says: 1080i/50z. Does it mean I am watching worse quality now because of that "interlaced" ??
Posted on Jan 27, 2009
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes.
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Problems with lg rz-42px11 load bang no picture
The set really needs to be looked at by a shop or an experienced tech, not going to get here and answer: press this button and that and it will be just fine.
Something clearly popped--since they only sell boards for this set it may need one or more or even if the panel or screen unit is involved be fatal---have it looked at to see what happened.
Apr 16, 2012 | Televison & Video
My LG 42pc1DV has sound normal but picture just died and is blacl, before this happened I had a lot of green pixels that only showed up across screen on dark pictures, 4 year old and just out of warrenty
Either your Y sustain board went out or your upper and lower Y buffer boards went out. Worst case scenario is your panel went out. But you won't know without replacing the other boards first.
Apr 10, 2012 | LG 42PC3D 42 in. Plasma Television
Our 57H81 is about 10 years old and we can hardly see the picture on tv/movies especially - when a dark scene is shown. Do we need to perform maintenance or change out the projection lights to get the...
You can try cleaning the lens/mirrors of the set with a lint free cloth and a cleaning liquid made for cleaning glass. The dark image can sometimes be caused due to dust on these parts. If that does not work then I am afraid that you need to purchase replacement CRTs(the three tubes at the back of the set). Each of them produce one color - Red, Green and Blue and all 3 have to be replaced to resolve the problem, unless you can visually identify a malfunction with one of the tubes(If one of tubes is a lot dimmer than the other 2).
Sep 18, 2011 | Toshiba 57H81 57" Rear Projection...
My brand new LG 37' Led/Lcd t.v. had four very light white spots that you can see in the background what causes this?
Dead and Stuck Pixels
Pixel defects for an LCD monitor are defined as one of two types: dead or stuck. Technically, both types of pixel defects are stuck pixels but it really deals with the electrical currents and the state of each pixel or sub-pixel.
A dead pixel is defined as a pixel or set of sub-pixels that has failed and is permanently in the off position. This condition means that the pixel will not let any light through. This can be observed as a dark or black spot on a brightly colored or white background.
A stuck pixel is defined as a pixel or sub-pixel that has failed and is permanently in the on position. This can be either with a single or multiple sub-pixels for a given pixel and is best observed on a dark or black background. A white pixel means all three sub-pixels have failed while a green, red or blue pixel means one of the sub-pixels has failed.
Hope this helps, if so do rate the solution
Jan 16, 2011 | LG 37LC7D 37 in. LCD HDTV
Getting light pixelation on dark scenes.
Sometimes a technician can make adjustments to the y-sus and z-sus boards on the panel. If that doesn't work then its either replace those boards along with the main driver board or replace the panel. Either way this requires a technician to look at the TV.
Nov 11, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Samsung le32r7 2yrs old
Well the shadow is caused by the pixels going dead. There is a term for this "dead pixels" if its still under warrenty take it in. If its not you may be able to get a new screen for it on I use ebay a lot and boy I found thing I though I would never find people are very informative and you will probably need to take the screen you bought to a repair shop and have them place it in for you. this is not a quick fix so I hope this helps.
Apr 23, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Scosche FIA-3A Tie into rear spekers of a 300C to power a sub amp
Hello herg1076,
Here's a link to which will have a page showing the color codes for your vehicle wiring. The 2008 Chrysler 300 rear speakers are shown as follows: Left positive is Dark Green/Tan, Left negative is Dark Green/Gray, Right positive is Dark Green/Brown, and Right negative is Yellow/Green. Other models and other years will be different, so be sure that you browse to the correct color codes for your specific vehicle.
Hope this helps.
Apr 22, 2009 | Scosche Industries Scosche Slc4 Speaker...
Green spot / glow in center left side of Panasonic PT-61LCX65 LCD Projection HDTV
This unit has a chonic issue with corruption in the eeprom that causes spots and shadows. The correction is to find some service center that has the jig to hook up to your unit and correct the eeprom. This is an extended warranty issue with Panasonic and if you contact them they should be able to refer you a qualifed service center and Panasonic will pay.
Apr 06, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Open Questions:
See all LG RU-42PX11 42 in. EDTV-Ready Plasma Television Questions
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
1,172 people viewed this question
Computer Repairing
Computer Repairing
