Question about Zanussi ZJ1217 Front Load Washer
Replacement cabinet door hinge
Zanussi zj1217 i need a replacement hinge for my cabinet door that attached to the washing machine where can i get one in Dublin /ireland or online thanks
  • 157 Answers
Search internet any zaussi dealer will order it for you.
Posted on Dec 31, 2008
I have a zanussi zj1217, when select any programme it sounds as it is about to start, but before any water even goes in the start/pause button starts flashing. Any idea's.
check pump /pump filter electronics can sense if the pump not working at the begining of the programme try a pump only prog.Can be heater or main motor with an earth fault. you need an insulation tester to isolate the fault.
Jul 25, 2010 | Zanussi ZJ1217 Front Load Washer
My washer is vibrating
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 21, 2010 | Zanussi ZJ1217 Front Load Washer
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
Zj1217 door not opening
you need to clean your pump there is a safety feature in the washer that will not allow it to open if there is water in the machine if you open the pump be sure to have plenty of towels
Dec 26, 2008 | Zanussi ZJ1217 Front Load Washer
Zanussi washing machine door seal removal
This is quite tricky, first take off the retaining ring on the front door port, remove the seal from this rim. The back of the seal is held by a spring band. the best way to remove it is to get a good grip on the seal at the top then lift and pull (thats the easy bit), to put the new one on i always lubricate the recess on the seal with washing-up liquid and feed the seal on from the bottom with one hand whilst following it around with the other hand to stop it coming off. Once it is fully on it can then be rotated easily into the correct position. Getting the spring back on will require an extra pair of hands for obvious reasons.
Good luck with it and keep the swear box handy lol.
Thank you for using fixya
Nov 26, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi Front loader washing machine
is the door loose( up/down movement) could be hinge problem,or the door lock may need replacing.
Mar 20, 2008 | Washing Machines
Zanussi ZJ1217 door seal
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Sep 03, 2007 | Zanussi ZJ1217 Front Load Washer
Zanussi ZJ1217 Front Load Washer Logo
151 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
