Question about GE (PSS26MSRSS) Side by Side Refrigerator
Having cooling and frezzer issues!!!
I have a GE GSS25JSRFSS and just lastnight out of no were it just stoped cooling and frezzing my items in the refrige. We just moved in to this house a month ago. Is there a recall on these refriges or am I going to have to call a GE guy out to fix the problem. Also do you know how old this refrige may be or when was it made? Please let me know as soon as possible.
Thanks,
  • 1 more comment
  • Bryan27 Jan 23, 2008
    Thanks for the tips on my refrige.. I had to reseed all the wires on the board and cleaned off the filter and pluged it back in and it worked. Thanx again tech17!!!
  • Anonymous Mar 18, 2008
    Freezer nor cold enough, Fridge too cold, freezing produce. I can hear fan, not compressor.
  • robert samples May 11, 2010
    can you hear a fan running in the freezer and is the compressor running
    President:
  • 1,314 Answers
If the compressor isn't running then pull the refrigerator out on the back of the unit on the freezer side is a cover about 5x6 or so with 3or 4 screws in it un plug the unit and remove that cover in side will see a circuit bd inspect it to see if any of its burned if it is contact ge at 1-800-gecares to see what they will do i know the new boards have been re done to correct the promblem but no recall i know of
Posted on Jan 22, 2008
I have a GE artica md417876 ps525mgna ww side by side the frezzer is not frezzing the food it sounds like the fan is working what can I do to fix this problem
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 25, 2011 | GE Profile Arctica 25.4 Cubic Feet...
I have a elderly lady that asked me to look at her freezer and see why it not working well i have cleaned it and checked all gaskets and to see if there is any power problems but nothing. I can get it the...
It sounds like a compressor issue either the unit has lost pressure on the free on side, bad compressor, low free on or gases, or cooling fan for the compressor to keep it cool stoped working. thanks
Oct 05, 2010 | Woods Chest Freezer C1501W3
Freezer frezzes up and fridge stops cooling we have defrosted it and it works for a couple of days and it does the same thing again
Defrost heater(s) and terminator are probably bad. Test for continuity across heater. If none replace both items.
Jan 09, 2010 | GE Refrigerators
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
Power surges in area now it wont frezze and barely cools down on food side
WELL IT SURE WASNT THRU YOU GUYS AND YOU SO CALLED FREE ADVICE SECTION --- ITS ALWAYS ABOUT THE FUCKIN MONEY ----HAVE A GREAT DAY
May 17, 2009 | Frigidaire FRS26R4A Side by Side...
Replacement light bulbs for GSS25JSRFSS.
TRY GOING TO A LIGTH STORE OR A SPECIALTY STORE OR TRY ONLINE. THEY A LITTLE DIFFERENT. FOR THE NOISE I WOULD REALLY HAVE IT CHECKED IT MAYBE SOMETHING SIMPLE BUT YOU NEVER NOW AND IS ANOYING ANYWAY
Sep 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Crosley refridgerator
the only probable cause why a freezer compartment will be hot is if the heater coil that used to heat the ice is still running even there are no more ice in the evaporator.
that will only happen if the bi-metal or thermo disc is shorted.
bi metal is a part where in it would open at 4 degress celcius in order for the defrost heater to stop heating. but if it is shorted then even though the evap temp is more than 4 degrees celcius, it is still heating up ang would make the freezer compart,ment hot.
i hope i answered your problems...
pls rate e..
tnx
drcool
Jul 18, 2008 | Whirlpool GS6NBEXR Side by Side...
Frezzer not frezzing
if you have a old refrigerator it is probaly dying this happened to my parrents fridge a couple years of ago so they got a newer frigde and it works good but if you by a fridge make sure you by name brands
Jun 23, 2008 | Refrigerators
Frost free frezzer
The drain is probably clogged. Use a pipe cleaner to clear and then use a turkey baster and force hot water through. Follow with a weak bleach solution. Drain is usually in the middle of the bottom. maybe towards the back. It is supposed to drain into a pan underneath the unit and then evaporate. Another solution could be a leaky door gasket. This overwhelms the defrost system and causes leaks.
Jun 16, 2008 | Frigidaire Freezer GLRT183TD
GE (PSS26MSRSS) Side by Side Refrigerator Logo
108 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
