Vertical is spread waaay too far. Vertical size and height pots have little or no effect. Noticed some discoloration (traces seem okay) of pc board in area of R505 and near some other 500 series components; resoldered, no help. Suspect an open R or a lytic or maybe the IC? Don't have a schematic or manual so unable to check pin volts or R values.
This is a Mitsubishi 60 rear proj model VS-6015R. Don't know how to locate chassis number.This is a Mitsubishi 60 rear proj model VS-6015R. Don't know how to locate chassis number.
Thanks for the site URL, Jaime. I scrolled through there, there was no ref to this model number in the list, and no "Symptom" at the Keyword "Vertical" that was appropriate... I have vertical deflection but cannot control the size/ht, and large vertical seperation at bottom of screen. Is the same for all three lamps, and convergence seems to be affected only slightly.Thanks for the site URL, Jaime. I scrolled through there, there was no ref to this model number in the list, and no "Symptom" at the Keyword "Vertical" that was appropriate... I have vertical deflection but cannot control the size/ht, and large vertical seperation at bottom of screen. Is the same for all three lamps, and convergence seems to be affected only slightly.
I would suggest to check the electrolitic capacitors around the vertical section for leaky or dry condition, normally the capacitors that become defective are less than 100uF.
Good Luck.I would suggest to check the electrolitic capacitors around the vertical section for leaky or dry condition, normally the capacitors that become defective are less than 100uF.
Good Luck.
You can't post conmments that contain an email address.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.) When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals. The most likely possibilities are in the deflection output stage or bad connections to the yoke
Most probably the vertical deflection amplifier is failing. The most common part that fails is the vertical output transistor. The set is too old to find documentation on part numbers and descriptions. Probably the part is no longer available and you will need the assistance of someone who can help you find an equivalent transistor that will do the job. Of course, without testing we cannot be certain the failure is the output transistor. It could be from something else such as the voltage regulator that feeds the dc line to the vertical section. Could be the vertical synchronous level that goes too low to trigger the vertical sweep generator.
Loss of vertical oscillator or vertical drive signals Good luck.
Hello, you can do this yourself by opening the back cover of the television CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
The most likely possibilities are in the deflection output stage or bad connections to the yoke. Hope it works well...
hello,
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
CAUTION: immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. may be a jumper plug or other means of selecting service mode - not an actual switch.
When moved to the 'service' position, it kills vertical deflection and video to the Tube. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection ports or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection ports on the Tubes.
Normal
0
false
false
false
What is the brand of TV and chassis number?
