Question about Akai PT5492S 54" Rear Projection Television
Power on the set nothing shows - Akai PT5492S 54" Rear Projection Television
  • 7 more comments
  • hkibob Mar 19, 2008
    Was getting picture and sound. Slowly lost both. Someone metioned the power supply. Is this hard to replace?
  • david375 Aug 28, 2008
    TV worked great. Go to turn on last night and nothing. No picture, no sound, nothing. Have checked to make sure there is power to the set. Is there a reset button or something that simple?
  • wmemories200 Sep 26, 2008
    My problem was similar in that I was watching it, left the room and when I came back had no picture, no sound and the power light was flashing.
  • panda41768 Oct 02, 2008
    how do i fix this problem can i do it my self and where do i get parts
  • Anonymous Oct 03, 2008
    power on set, nothing happens. no picture, sound,nothing
  • bobkelm Oct 03, 2008
    push power button and nothing happens
  • biggs450 Oct 13, 2008
    Had a really bad storm. TV was plugged into a power strip instead of surge protector. Red light comes on but no pictur or sound
  • Anonymous Nov 13, 2008
    tv will not turn on, i have replaced the power board and still will not work
  • wifemother May 11, 2010
    how do i solve it
  • Akai Master
  • 8,617 Answers
You ether have a blown fuse, or a power supply. what make and model set do you have. I will be better able to help you.
Posted on Jan 22, 2008
6ya staff
SOURCE:
My stove will not work it always shows PF how do I fix this as nothing works
PF is most likely power failure. Nothing responds in keypad? Try setting clock. If nothing responds, your control is probably bad.
Sep 16, 2017 | Ovens
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney ([email protected])
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
TV HAS RED LIGHT SHOWING WILL NOT SWITCH ON
Hi, The red light shows there is power connected to the set. The fact that it won't power up is due to a problem with the power supply circuit in the set. or a problem with the switch circuit or the mains power transformer. Regards John Ps don't know why they're giving me these questions, I answer questions on auto's
Feb 12, 2012 | Wharfedale Televison & Video
I have a TERASTATION PRO II 2TB 2URM NAS 4X500GB. It seems to be shutting down unexpectedly. I have all the sleep modes disabled and the switch on the back set to auto. No temp issues and I have it...
no i would concentrate on the date time issue than see if you have any more problems i wish you the best of luck and if it works out OK please give me a good vote
Nov 29, 2010 | BuffaloShop Buffalo's TeraStation Pro II...
P4C800E Deluxe Motherboard Problem
A bad checksum can be caused by a flat or near flat BIOS battery. Replace the battery and set the date and time.
Also set the BIOS to the default setup, ie go to reload default settings, or remove the BIOS battery for 1/2 hour the insert the battery and set the Date and Time.
Jul 24, 2009 | ASUS P4C800-E Deluxe Motherboard
VS-45603 we have power but nothing else will show up on screen.
I would suspect bad solder connections on the convergence IC's caused one to short out a blow one or more pico fuses, thus causing the set to go into shutdown so as to stop further damage to the set. The TV will need to be seen by a profesional to confirm or deny this.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
PS2 slim powers on, but nothing shows on the screen
have you checked that the av cables are pluged in properly???
Oct 09, 2008 | Sony PlayStation 2 (PS2) Console
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Akai PT5492S 54" Rear Projection Television Logo
60 people viewed this question
Top Akai Televison & Video Experts
KISHORE DESHPANDE
Ekse
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
