Question about Xerox DocuColor 12 Printer
DOCUCOLOR 12 when i switch on the printer, i get a system fault - switch off, pause and power on again" message with an error code 3-380. I tried many times but getting the same message again Thanks Nathan
    President:
  • 2,072 Answers
    Problem Solver:
  • 4 Answers
I had this same problem a long time ago. I believe the problem was a faulty IR sensor somewhere in the system. You'll need a tech to replace it, it's not something you can do on your own.
Posted on Feb 15, 2008
Error 9-357
The answer I found seems unlikely but please give this a try:
Solutions for : Black Toner Empty Message Related Fault Codes: 9-274, 9-357, 9-368, 9-400, 9-453
Solutions ranked by relevance:
  1. Replace the Toner (Dry Ink) Cartridge
  2. Power OFF, Wait 30 Seconds, Then Power ON
To investigate further please see this website:
http://www.support.xerox.com/support/docucolor-12/support/enus.html?operatingSystem=winxp&fileLanguage=en&&associatedProduct=fiery-ex12
Trust this is helpful. PLease vote to show your appreciation. :)
Dec 10, 2010 | Xerox DocuColor 12 Printer
Our xerox dc12 gives a message system fault turn power off the swith is on the right side pause and turn back on Code 9-357
The error 9-357 normally refers to a toner issue.
This normally refers to a color/Black toner problem. Probably there is low toner sensor defect.
Check for the ink in the cartridges as well but before that try to vacuum and clean the toner dispenser. You must vacuum whole path which is used to transport the toner to developer unit.
Feb 28, 2010 | Xerox DocuColor 12 Color Copier
Xerox dc-12 system fault - Error code 10-389
that could be your fuser/youll maybe have to reset an nwm
Aug 30, 2009 | Xerox DocuColor 12 Printer
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Eror code 3-380 System Fault problem
Whenever switchon my Dc12 The mahinc ready within 5 minutes and final stage it shows the eror like "System Fault" error code 3 -380 Switch of your printer and on. How can I solve it.
Oct 15, 2008 | Xerox DocuColor 12 Color Copier
Xerox docucolor system fault problem
hi please chek and tell what error code showes in your display.. some error codes showing in ur display, pls check it that.
Aug 25, 2008 | Xerox DocuColor 12 Printer
Docucolor 12 system fault turn off and turn on problem
tell about error code which is appear left bootom of screen
XEROX DOCUCOLOR 12 - Booting
if u getting this message in ur fiery just reinstal software... this only solution... and if u get this error in ur printer pls check error code in bottom of the display..
Aug 21, 2008 | Xerox DocuColor 12 Printer
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Printer Logo
169 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
