Have a problem loading cartridges for a C3100 All-in-One. They do no click into place, and the black cartridge is popping out after the door is closed.
  • 50 Answers
Have you checked for any obstructions in the carriage? And I assume you are using the proper cartridge for the printer (92 for black and 93 for color)
Posted on Jan 23, 2008
Where is the ink cartridge located on the HP c3140 and how to I get to it?
From the manual:
Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you open the print cartridge door
to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a
print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
from the slot on the right.
Chapter 1
14 HP Photosmart C3100 All-in-One series
HP All-in-One overview
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridge
Jul 24, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
How to change printer cartridge in a hp c4240
I hope this will help with your installation of printer cartridges for your HP C4240 printer. It's really a fairly easy process.
  1. Pull down the cartridge cover door located above the paper tray -- and wait while the carriage slides to the right.
  1. Open your replacement print cartridges and remove the protective plastic tape.
  2. Press the black cartridge into the right-hand slot until it clicks into place. It'll only go one-way.
  3. Load the tri-colored cartridge into the left slot.
  4. Close the print cartridge door and wait while a test page is printed.
Apr 11, 2011 | HP Office Equipment & Supplies
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    COULD YOU PLEASE TELL ME WHERE AND WHAT PRICE I SHOULD BE PAYING FOR HP 92 AND 95 CARTRIDGES
    You will be able to place order for these cartridges on the HP website.
    Click on the link to launch HP website and place the order.
    When the HP website is open, In the Search on right side top corner type HP 92 and hit enter key.
    It will show the HP 92 Black Cartridge ( Add it to cart )
    Do the same for HP 95 and add it to cart and later Checkout from top right corner to continue placing the order.
    HP 92 cost you $14.99 ( single cartridge )
    HP 95 cost you $28.99 ( single cartridge )
    www.HPSHOPPING.com
    The price is same on both the sites ( HP and Bestbuy )
    Hope this solve your issue.
    Thank you for contacting FixYa
    * Rating and Comments are invited on this solution
    Nov 11, 2010 | HP Photosmart C3100
    Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
    1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
      Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
    2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
      Repeat whenever you run out of ink.
    Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
    How do print black only on a HP C3100
    maybe you just need to check the "grayscale printing" option in the printer menu..
    May 27, 2009 | HP Office Equipment & Supplies
    Instructions on installing & changing ink cartridges
    Step ten: Install the cartridges
    1. Make sure the product is turned on. The On button is lit when the product is on.
    2. Lift the cartridge door. The carriage moves to the right side of the product. Figure 12: Lift the cartridge door c01331661.jpg
    3. Remove the new cartridge from its packaging and gently remove the plastic tape using the pink pull tab. Figure 13: Remove the tape c01331662.jpg CAUTION: Do not touch copper-colored contacts or retape the cartridges.c01331663.jpg
    4. Slide the tri-color cartridge into the left slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place. Figure 14: Insert the tri-color cartridge c00620861.gif
    5. Slide the black or photo cartridge into the right slot. Push the top part of the cartridge firmly up and into the slot until it snaps into place. Figure 15: Insert the black or photo cartridge c00620862.gif
    6. Close the cartridge door.
    Step eleven: Align the cartridges
    1. Make sure you have loaded plain white letter or A4 paper in the bottom tray. Press OK to print the alignment page.
    2. Remove the alignment page from the output tray. Figure 16: Print the cartridge alignment page c00620112.gif
    3. Place the alignment page face down into the document feeder. Figure 17: Load the printed alignment page c00620113.gif
    4. Press OK to scan the alignment page. After the page has scanned, alignment is complete
    Apr 12, 2009 | HP OfficeJet 4315 All-In-One InkJet...
    I need assistance changng the black ink cartridge on my MFC 24OC brother
    1. I have this printer myself.
    2. Facing the printer, look on the far right corner.
    3. You will see a little door below the scanner. This is where the single black and three color cartridges reside.
    4. Open the door and see the cartridges.
    5. The black will be the one that is to the far left in this compartment.
    6. Each cartridge is secured by a blue vertical "lever"
    7. Push on the blue lever and it should click and pop out slightly.
    8. With your index finger, pull down on the lever and the cartridge should pop out even further.
    9. Let the blue lever drop down and grasp the cartridge and pull toward you. The cartridge should come out.
    10. Remove the cover and tape from the new cartridge and put in the black cartridge slot until seated in the slot.
    11. Gently lift the blue lever until it clicks
    12. Close the door and the printer will begin to clean itself automatically.
    If my assistance has helped you, please complete the rating. Thanks for using Fixya.com
    Jan 27, 2009 | Brother Multi-Function Center MFC-240C...
    How do I change the ink cartridge in my Lexmark x2470
    How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
    1. Make sure that plain paper is loaded in the paper tray.
    2. Ensure that the power light is on.
    3. Open the cartridge door.
      The cartridge carrier may move slightly, and then return to the loading position.
    4. Push up on the cartridge lever.The cartridge holder springs open.
    5. Remove the old print cartridge and dispose of it.
    6. Remove the sticker and transparent tape from the new print cartridge.
      Warning! Do not touch the gold contact area on the print cartridge.
    7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
      Insert the color cartridge in the front carrier slot.
      Insert the black cartridge in the back carrier slot.
    8. Close the cartridge door.
    9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
    10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
    Please Rate the solution.
    All the Best
    Sammy
    Sep 26, 2008 | Lexmark Office Equipment & Supplies
    My C3100 HP all-in-one printer prints a test page everytime I want a single copy. How can I print before wasting ink on a test page?
    cannot load new ink cartridge c 3150 black cartridge keeps popping out when you close acces door help thanks harry
    Apr 23, 2008 | HP Office Equipment & Supplies
    Computers & Internet Logo
    David Payne
    David Payne
