Hi from uk all wheels on your vehicle should be fully interchangable to any axle/side however on a number of cars now the spare wheel in uk are a what is called SPACE SAVER this is usually a steel rim painted red with a smaller tyre that is for emergency/get you home only till origional wheel /tyre is fixed ?? only other problem you could have with wheels/tyrs when interchanging is many high spec wheels are what is called ROTATIONAL TREADS the tread pattern on each tyre must be fitted correctly in rotation of wheel for displacement of rain on road for one instance ? so if you change wheel from right front to left ? the rotation pattern on tyre faces wrong way hope you understand ?
