Question about Sony FD Trinitron WEGA KV-36FV300 36" TV
Blank screen My 5 yr old sony kv-36fv300. I turned it off one day and It has never turned back on. It sounds like it is trying to power up but there is never a picture or sound. Tried the resset button but the power light just flashes. Thanks T
These tvs are known for bad power supply capacitors. Try power cycling the tv several times (8-10) to see if it finally comes up. Four flashes indicates a power supply problem or a deflection problem, usually it is the first. Take the set into a shop if you are not an electronics technician, as these are dangerous areas to work on. Otherwise, use a capacitor checker to test the caps, starting with the main supply caps which are usually 200v. I've found these to be low by 200uf. Also, check the 1000uf and 2200 uf caps. These will be low by 100 - 200uf.
It could be a flyback or deflection problem, but check those caps first.
Posted on Jan 22, 2008
The tv turns on and off and blinks five times
  1. Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.google.com/+GopakumarGopalan
Nov 18, 2013 | Sony FD Trinitron WEGA KV-36FV300 36" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
May 04, 2010 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron KV-40XBR800 wont turn on
30 YR SERVICE TECH.
YOUR UNIT IS EXPERIENCING A POWER SUPPLY FAILURE.(INTERNALLY)
TAKE TO A SONY AUTHORIZED SERVICER.
Jan 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
Jun 04, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony 36fg-36fv300
plug tv directly into the wall and not through the cable box.
Jan 20, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
No picture
This mogiht be a problem in the High Voltage power supply. Or the Horizontal output section of the TV. I would start off by checking the Horizontal Output Transistor and the using a high voltage probe check the CRT anode voltage to make sure it is proper. If you do not have a background in electronics I would not suggest that you attempt to work on this set.
Oct 11, 2007 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Tv stopped working
HV problem. I'm sorry but there is a time for the TV dudes to come see everyone and this is your turn...accordianman
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony Trinitron TV will not turn on
First thing that comes to mind is that the horizontal driver transformer has bad solder connections on the primary and the secondary windings. Also a set this old could also have a defective regulator IC if you dont know wht m saying , b=est thing to do is find out how much an estimate is then go back to best buy and see what a new set cost cause man you got your moneys worth outa this one for sure!!!!! Good Luck
May 02, 2006 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony FD Trinitron WEGA KV-36FV300 36" TV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
