Question about Sharp AL-1655CS Laser Printer
SHARP AR-M277 i HAVE A H4-00 ERROR CODE. HELP
    President:
  • 2,072 Answers
This should resolve it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Posted on Jan 22, 2008
  • Rick Kasper Feb 19, 2008
    If that procedure did not work. You need to replace the fuser, then repeat that software reset. Sorry for the delay in the re responce, if that is a word...
F2 70 error code on sharp ar-5618, how can i resolve it.
i have sharp ar 5620n it is showing error f2-70 what might be the course
Sep 06, 2013 | Sharp AR-M277 Digital Copier Copier
Due to a power surge, my Sharp AR-M277 won't turn
There is a 20A fuse on the AC power board it is most likely blown. Follow the power cable to the board the big white ceramic fuse is the main, check continuity with meter and replace.
Sep 02, 2011 | Sharp AR-M277 Digital Copier Copier
We had a power outage and now the copier shows Error Code H4-01. What do I do ? Please help !
Hi have you tried to doing a trouble clear, this is a fusing unit heating error!
Do you know how t do a reouble clear?
Jul 12, 2011 | Sharp AR-M277 Digital Copier Copier
Does a Sharp AR-M277 use 1 or 2 bags of developer?
Hi, the Sharp AR-M277 takes 1 bag developer (type AR-271MD).
Jan 05, 2011 | Sharp AR-M277 Digital Copier Copier
How to scan a document using a Sharp copier model number AR-M277.
Requires optional network scan kit. When installed it comes with software for scanning
Jul 17, 2010 | Sharp AR-M277 Digital Copier Copier
We have a Sharp AR-M277. The screen says maintenance required.
Hello sir; Which means is you need a PM that including replace drum, drum blade, developer, corona wire etc. very complicate, if you really interest let me know, I'm happy to give you instruction.
Oct 26, 2009 | Sharp AR-M277 Digital Copier Copier
H2-00 Error Code, cant clear
Sounds like a tough one, take off the back cover and make sure all connectors are making good contact. You may have a fault in the main logic board.
This might need a tech to check out.
Hope that helps...
Apr 25, 2008 | Sharp AR-M277 All-In-One Printer
Sharp AL-1655CS Laser Printer Logo
507 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
