Question about Pentax Optio 555 Digital Camera
Pentax 555 my pctures come out on my laptop as if everyone is wider than they are - the problem continues when i share them with friends -
0 characters
1 Points
How large of a disc will this camera take and format?
The Optio 555 uses MMC and SD cards up to 2GB in size.
Nov 02, 2013 | Pentax Optio 555 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Does the Pentax Optio 55 take the scan disk 8gb sdhc memory card.
NO! its maximum is 2gb. Also using high capacity cards slows the recovery down between shots, stick to smaller value cards for speed of access
Jul 06, 2009 | Pentax Optio 555 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Optio 555 Battery Compartment cover problem
My Optio 450 has the same type of cover and I am surprised how tough the cover is. I thought it would have broken by now. I suggest a call to Pentax would answer your question about getting it fixed. Alternatively, just leave it. The Plastic hinge should keep it closed
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Is it possible to use an SD memory of 1 GB in Optio 555
I think its a lucky dip! Maybe better off with 2x 512MB
Aug 30, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio 555 Digital Camera Logo
14 people viewed this question
Top Pentax Digital Cameras Experts
Are you a Pentax Digital Camera Expert? Answer questions, earn points and help others
