Question about Weather King 12AJA4801AH Air Conditioner
What part do we replace first?
Weather King propane heater stopped working at all. Nothing comes on at all you can hear the thermostat click to come on but nothing works. Ignitor does not come on and glow and blower does not come on.Power is ok to the unit.Where should we start to troubleshoot the bad part? Model # WGPH-05EAUER
  • 1,420 Answers
Door safety switch. You are sure you have power to furnace? jump out the G and R terminals on the furnace control board or turn your thermostat to Fan On to check. Make sure the door safety switch is in the closed position. Fan should come on. No fan, no power to unit. Check Emergency switch, circuit breaker and there may be a fuseable link in the wiring somewhere either above the unit or a condensate safety switch. Get power to the unit. Also check to see if there is a small fuse in the wiring inside the furnace or on the circuit board.
Posted on Jan 23, 2008
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
Rv furnace stopped working
Quick call the installer to see if it is still under warranty. There is something wrong if the motor is being replaced every other year. Most of the motors should be lubed with fan turbine oil and not 3 in 1, nor detergent containing oils. If the wrong oil is used, the bearings will go south in 1 to 2 years.
Nov 23, 2013 | Heating & Cooling
The WeatherKing Forced air heater stopped working in my house. The thermostat could turn it on in terms of sound but when I looked at the heater, all I saw is the pilot light. No air, hot or cold, was...
You will need to relite the pilot if this is a standing pilot furnace........If this has an electronic lite for the pilot then cycle power to the furnace and set thermostat to heat. and retry sequence. Once you get the pilot to lite then watch it to see if the main gas comes on. if it doesn't then you need to check and see if you are getting 24 volts to the gas valve with a volt meter. If you don't feel comfortable with doing this then you will have done everything that is simple. You will have to call a service tech. Problems that it could be are gas valve, limits not closed, ignition control board, main limit open because the blowor motor locked up or motor has open winding or run capacitor open.
Jan 02, 2011 | Weather King Heating & Cooling
Cool air comes out when the heat turns on. When I switch to Em heat, warm air comes out. Over the summer the air worker great, however when I switched to heat on the thermostat, cool air came out. Why?
Check the following. 1. Your setting temp must be higher +3 than room temp. 2. Check heating sensor.3. And also heater element.(If it's reversal valve, checke RV is working)
Dec 12, 2010 | Weather King 10AJA3601AH Air Conditioner
Patio Heater SRPH02 will not light in cold weather
you may need someone to come in and adjust your pressure regulator that is inline to heater this is what controls the output of propane and should only be adjusted by a pro
Apr 15, 2009 | Coleman 5040-751 BackHome Open Flame Patio...
Bosch tankless hot water heater 1600H
it sounds more like the ignitor thats messing up, if you are able to remove it and get a new one that would probobly do it for you
Nov 07, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Weather King AC
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Aug 19, 2008 | Weather King 10AJA6001AH Air Conditioner
No heat
First figure out if your unit is a heat pump, (where the unit outside both heats and cools your home) or it may be a propane or nat gas furnace, it could also be a hydronic heater (the water heater heats the home) let me know what you find out.
Oct 30, 2007 | Weather King 10AJA2501AH Air Conditioner
Weather King 12AJA4801AH Air Conditioner Logo
184 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
