Question about Car Audio & Video
Am trying to find color codes for audio system on a '97 altima,
Bought the car and there is nothing but cut wires where the head unit was. have a new unit to install but cant figure out the wireing.
    Scholar:
  • 75 Answers
Www.installdr.com
has probably 90% of the cars that you run into that people weren't smart enough to just buy the wiring harness and just cut off the original stock harness.
Hope this helps.
Posted on Jan 22, 2008
    Problem Solver:
  • 5 Answers
My suggestion is to head down to Autozone and purchase a Haynes Repair Manual for the make and model of your car. Toward the back, you'll find a bunch of wiring diagrams, one of which should be for the audio system. Most importantly, the diagram will tell you what colors the wires should be.
Posted on Oct 23, 2009
Wiring for radiator fan
Is it the same amount of wires ? Is the plug the same?Take a circut tester and determine which is common and which is ground and connect accordingly
Jun 30, 2012 | 1998 Nissan Altima
Tip
Never Cut The Stock Harness.
The best advise I can give and the worst mistake you can make while trying to install a new head unit into a car is DO NOT CUT THE STOCK HARNESS.
New head units come with bare harness with just wire ends, so you may think you need to cut off the harness on the car to wire it in.
This is the worst thing you can do. As a matter of fact, it is a bad Idea to cut any harness for anything in your car as they make wiring harness adapters to fit every thing in your car.
Before you install your head unit, go to Best Buy, or any car audio place, or on the internet and get a harness to suit the install. For instance if you have a pioneer head unit, and a 2007 Honda, you want a pioneer to 07 Honda wiring harness. This will allow your head unit to connect right into the stock wiring harness.
The same can be done for the speakers as well.
on Jan 01, 2010 | Car Audio & Video
I have a 97 toyota tocoma ext.cab. and am putting in my new cd player although my wires are not the same colors could you tell me what wires i need to match
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Apr 06, 2011 | Alpine 16 Pin Original Head Unit Harness
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
I am changing my head unit and i dont know what color wires go to what on the stock one
The auto and radio Dons have blessed us with a universal color code for all vehicles-that I've noted in all the systems that I've changed. If you're swapping out the stock Chrysler system you'll need to go to Walmart-or a store that sells audio equipment-to buy the Dodge/chrysler/jeep adapter. You connect it to the factory connect and splice the same colors to the radio. Most times the wire have the speaker it goes to written on it. If you have already cut the connector off and can't reconnect the wires, just match up the wires with the matching colors. Hope this helps.
Jul 27, 2009 | 1998 Jeep Cherokee
I had my head unit put in by a audio shop and when i got my car (1993 Saab 9000 CSE Turbo) back my rear speakers dint work so i took the head unit out(because the shop would not fix it or refund me and i...
If the rear speakers worked before your new head unit was installed, then the first question is does your new head unit have the facility to feed four speakers. Some systems will only power two speakers. The Audio Shop should have rectified the fault - you paid for the installation and as the customer you have a reasonable expectation that they would do it properly and ensure that all of the existing speakers were functioning properly. It would be worth challenging them again - if they refuse you could go to Citizen's Advice Bureaux or the nearest Trading Standards Office. Alternatively, try tracing the wires back from the rear speakers to the head unit - are the wires connected up properly... at both ends (i.e., the speaker end and the head unit).
The audio shop has probably hard wired the head unit because the sockets in the back of the head unit were not compatible with the plugs that came as standard with the car. A Haynes Manual or equivalent will give the colour codes for the various wires for the audio system.
Jun 26, 2009 | 1993 Saab 9000 Hatchback
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
Hi, I am installing a new head unit into my dads 98' Buick LeSabre and the factory harness has been cut and I'm not sure of the color code and not sure how to run the extras thru the new head unit and how...
Metra makes wire harnesses for your problem. If your wire harness is, 70-5555 the part that goes into the OEM radio will be 71-5555
Try www.metraonline.com and put in the car info. The harness will come with wire codes for splicing the new plug.
Dec 17, 2008 | Car Audio & Video
Wire color code for 2001 explorer factory cd cassette player
the radios will not interchange you are better off getting an aftermarket radio and harness adapter,if you haven't cut the factory wires on your truck.if so let me nkow
Dec 11, 2008 | Car Audio & Video
Pioneer DEH-1500 installation issues
Get a new unit. The damage was done before the smoke was present.
Jul 28, 2017 | Pioneer DEH-1500 CD Player
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
