Question about HP LaserJet 5p Printer
Connection plug from printer into laptop
My old HP Laserjet 5P printer is still working brilliantly but the connection plug it has only fits the old desktop computer rather than my laptop. What do a i need to plug into a laptop USB socket?
  • nordicman Nov 17, 2008
    I had the same problem: connecting my old HP Laserjet 5P to a new Macbook. I'm wondering whether the solution suggested here back in January of '08 (a Sabrent 6-Foot USB 2.0 to Parallel Printer Adapter Cable) actually worked. I picked up an adapter cable at a local store (maybe not the same one recommended at this site) and found that the parallel connection on the end of the 5P's printer cable wouldn't connect (they weren't the same widths across). The store I was at said HP sometimes used propietary equipment that didn't work with standardized products. FYI - the cable coming out of my HP 5P is hard wired into the printer and had a parallel connection on the end of the cable that was connected to my old PC. So, I do need an adapter cable for connecting to the USB port on my new laptop but it appears the old HP 5P's parallel connector was not a standard size. Do you know if the adapter cable recommended earlier at this site actually will fit the parallel end coming out of the 5P? Thanks much! - Jim
  • AKMINR Apr 14, 2009
    where do I plug in my Printer on my Acer 2480 Laptop
  • 26 Answers
Http://www.tigerdirect.com/applications/searchtools/item-details-print.asp?EdpNo=1219598&Sku=M501-1058
here's what you need , This is the best solution to converts USB signal to parallel port signals
Posted on Jan 22, 2008
I've try to connect my HP laserjet 5p printer to my mac g4, I purchased a USB cable. It prints unreadable text and won't stop, any ideals?
Make sure that you are using the correct drivers for your printer, run through the printer setup again and then check the print.
Jul 13, 2011 | HP LaserJet 5p Printer
R@hotmail.co.ukplease show where to plug laptop into printer
The 5P has connections in the back of the printer, left hand side, under a removable panel. The power plug is under a similar panel on the right side. (as you face the printer from the front) There are connections for appletalk and serial under that left panel but not USB. If you want to use this printer with a modern computer you will have to work from either a serial port or an ethernet converter such as the Asante. Plug the ethernet into your router or RJ 45 jack on the computer and on the Asante. Plug appletalk from the round connector on the Assante into the HP 5P. NOTE: The 5p will not work with a Mac. The 5MP printer will.
Mar 25, 2011 | HP LaserJet 5p Printer
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
Just installed and am getting an error message from the printer but not from the computer, on the pc, the driver is installedbut it will not print.
I purchased a Dynex USB to Parallel Converter Cable from Best Buy and tried to connect but had no success. I then sent an email to Dynex customer service and received a reply in about 24 hours. The rep provided spot on instructions which I was able to follow to a tee. My 14 year old HP Laserjet 5P is now ready to run until it blows up.
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable
Sep 24, 2009 | HP LaserJet 5p Printer
Vista will not print to HP Laserjet 5p
I spent hours searching web forums and only received overcomplicated replies by people who think they are techies, none of which worked. I am 63 years old and not a techie, so if I can do it, anyone can. I have saved the email and will forward this straightforward simple fix to anyone who needs it. My net cost was $36.00 for the cable.
Sep 05, 2009 | HP LaserJet 5p Printer
Have to keep setting up HPLJ 5P on a USB port everytime I print!
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP LaserJet 5p Printer
I recently installed my hp laserjet 5p printer yet its not printing
Is the driver installed? Do you see it in the printer section/
Nov 11, 2007 | HP LaserJet 5p Printer
HP LaserJet 5p Printer Logo
1,246 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
