Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Lace pattern on screen
Lace pattern covers 1/8th of screen. Remains constant.
  • 43 Answers
This sounds like what Sony refers to as "road mapping" and is caused by a bad lcd panel in the optical block. If this in fact is the case then it would be cheaper to buy a new tv. Sorry for the bad news. Opticla blocks run from $600 and up depending on the model. Of couse without actually seeing what you are describing I am speculating. You may want to have a Sony ASC look at the tv to verify this. Hope this helps you out.
Posted on Jan 23, 2008
What type of bra should be wore under a net lace filled gown?
A camisole bra the same color as the gown. It's more elegant, and will show off your lace pattern.
Sep 18, 2017 | Clothing
Finding knitting patterns for fine lace knitted dresses for ladies
There are many Lace Dresses available in the market or in the online stores. If you want to select knitting patterns for fine lace knitted dress than you should definitely try this online boutique and that is lily boutique.
You may find many varieties and designs according to your choice. You can also select another pattern as like navy colour dresses and many more parties wear dresses.
Feb 25, 2017 | Sewing Machines
How to lace a bike rim
First, you need to know
1) the type and size of hub, and
2) size and type of rim. Then you need to know
3) the type of spoke lacing pattern that you want to use in your wheel.
From this information you can determine what type and length of spokes are needed for your project. Most bike shops have access to books and software that can determine your spoke lengths.
Next is how to lace.. will add that later
Oct 13, 2014 | Cycling
What is yfwd?
yfwd = yarn forward
This is an eyelet hole which appears between 2 Knit stitches.
If worked between after the 5th knit (K) stitch in a pattern, it would be written in the pattern thus: K5, yfwd, K...
**To work this, bring the yarn between the needles to the front of the work as shown here.
All you do to complete a yfwd is to bring the yarn towards you.
Sep 07, 2014 | Computers & Internet
Rapid lace system problems.. uneven lace
Hi All,
I had an uneven problem with the DC Siloh '09s. Not sure if it will cover all makes and models but I will explain how I fixed it.
Key for the instructions:
Numbering the laces from top to bottom 1-8, outer side of the boot = little toe, innerside = big toe, and on the two laces that lock on either side of the boot (4 in total) toe and heel lace.
1. In order to make the laces even again you need to unlock the heelside lace on the outerside of your boot, this lace controls lace 3.
2. Pull lace 3 using creating slack now that it is unlocked
3. Pull the slack through lace 4 and then 5.
4. Once you have slack in lace 5 unlock the toe side lace on the inner side of your boot.
5. Holding that same lace pull the slack through the locking mechanism until you are happy with the balance.
For moving slackness from the inner to the outerside the opposite approach applies.
If it is not clear, reply and I'll try and take a photo or post a video or something.
Aug 12, 2012 | DC Shoes DC Methvin Snowboard Boot Men
Genuine belt too long for lace pattern used
Hi, I will try to help you or give you suggestions for your problem. If you have an OEM belt, it should fit. Try the install again and pay real close attention to the pattern that they give you. I found some patterns really difficult to lace and had to try over and over and finally got it. Your problem could be with the tensioner and idler pulley if you have both in your pattern. Check them out. The spring for belt tightening might be broken or something sticking in that assembly. Some have 2 belt tensioners, so if you do, take a real close look at them. Some systems have a fixed idler pulley that can be adjusted, so take a close look at each pulley you have in that pattern and make sure nothing is sticking. You might as well oil and grease the system so you don't have any problems for awhile.That is about all I can think of at this time, so I hope this helps you out a bit. All the best and good luck. I will answer any more questions you might have.
Feb 10, 2011 | Husqvarna Garden
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Hope this was helpful.
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
