Question about Fuji FinePix F650 Digital Camera
Fuji F650 won't turn on
My Fuji F650 just stopped working - went to turn it on yesterday and nothing happened. Recharged the battery, tried again, still nothing. I wonder if the switch on the battery/memory cover has malfunctioned since the camera is designed to not turn on if that cover is open.
  • Wreckage Aug 07, 2008
    Similar problem; camera working great then one day, only the green indicator light comes on but nothing else. I can only get the light off by removing the battery. I checked both solutions (battery door switch and USB connection) but did not help. Any ideas??
  • DDSki Oct 02, 2008
    Went to turn on my camera, the green light came on and nothing else happened. I pressed the on button again but no green light. If I take out the battery (which is fully charged) and put it back in, the green light comes on again but only on the first push of the on button.
Had the same problem.
I 'fixed' it by connecting it to the computer by the usb cord.
Hit the power button, turned on. Works properly (for now).
Posted on May 31, 2008
    President:
  • 423 Answers
Check the underside of the battery door. There should be an "L" shaped tab which presses on the shut-off switch. These are often broken off when closing the compartment. If it's broken off, you can defeat the switch by stuffing a piece of paper in it, and then closing the door (with battery installed). If the tab's not broken, you're probably in need of the service department.
Posted on Jan 22, 2008
The main screen on my Casio G'zOne Ravine (C751)
Let it charge for 24 hours before trying again. Battery may be too weak to light up the display yet.
Sep 24, 2013 | Cell Phones
I got my camera 3 weeks ago. Now Im on vacation in Thailand and used the camera snorkeling. Yesterday the camera "froze" so the only way to get it going again was to remove the battery. Today...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Feb 04, 2011 | Pentax Optio W90 Digital Camera
The laptop was unplugged and went into standby mode when the battery ran out. I have recharged the battery but the standby indicator is still on and nothing happens when I try to start it.
can you take out your battery and plug in the power? if it works, i suspected it's a battery faulty. if not please make sure to charge up your battery up to 100% then boot up your machine normally.
May 28, 2009 | IBM ThinkPad R40 2722 Notebook
Sanyo VPC-E1075: Cannot turn on camera
after two days of periodic checking if it'll come one... it finally did! don't know how... but i took out the battery and recharged it for a while, inserted it and turned it on but it didn't work. i did it again about two times and still nothing. so i left the battery outside for like a day.. and when i tried it again, it worked! thank God! thank you for your time.
Apr 18, 2009 | Fuji FinePix E500 Digital Camera
Van has been starting ok but yesterday battery was flat. Tried to bump start it but ended up getting a jump start. Drove it for approx 5 miles but had to put lights & heater on. Left it for a couple of...
5 miles is not enough to recharge battery. Have battery completely recharged or take it to major auto parts store where they can test battery,
What caused battery to go "flat"? Did you leave dome light on?
Dec 28, 2008 | 1999 GMC Sierra
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Fuji F650 camera 1yr old. Worked great till the other day I went to turn it on the green light came on but nothing else happened. I recharged the battery but it still does not work. The green light will...
the battery is not holding charge anylonger.need to buy new one (aprox $9 on ebay) or try to have it rplaced atthe store you bought the camera from (it should last more than 1 year for sure)
Oct 02, 2008 | Cameras
Fujifilm F650 Zoom Error
My camera stays open, will not shut, and when I turn it on the screen says "zoom error" and then turns off again
May 20, 2008 | Fuji FinePix F650 Digital Camera
Camera will not come on
try to use another battery and if it does not work please contact the manufacturer to get the camera replaced.
May 07, 2008 | Fuji FinePix Z10fd Digital Camera
Fuji FinePix F650 Digital Camera Logo
179 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
