Question about Koss KS3102 System
Ks3102 My home threater system will not play any dvd no more. it says reading for a few seconds than it say no disk
    New Friend:
  • 44 Answers
Try several different DVD's and if it still doesnt work clean the dvd player if that does not fix it replace dvd player.
Posted on Jan 22, 2008
6ya staff
SOURCE:
JSI JS5001 DIGITAL HOME THEATER RECEIVER/DVD PLAYER w/ 5 Speakers & Woofer
Make sure your speakers and dvd player disk is clean. Skips are common from the lazer reading and will read much better with a quick check on the cd.
May 02, 2015 | home Audio Players & Recorders
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
I have a Digital Home Theater HT-DS400 Samsung. I have problems in reading a music CD or a DVD. You can read the message "Loading.." for a while and then stops and reads "NO DISC". ...
  • Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  • If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  • The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 23, 2011 | Samsung HT-DS400 System
Sound no picture
Hi,i suggests there is a loose or broken connection on your video connections between the Koss KS3102 System dvd player and tv. Having sound suggests the optical pickup is fine. If you did not have sound then the Koss KS3102 System dvd player could have been broken. If checking the connections doesn't work, try a cleaning disk.
Take care.
Mar 25, 2011 | Koss KS3102 System
My Samsung HT-Z210 Home Theatre System is crazy. Sometimes it plays the disks but most of the times it would sound as if it is trying to load a few times and then displays disk error and if it does play...
Check for fingerprints or dirt on your DVD. Wipe it clean and try again. Also check for scratches. Try another DVD and see if your system reads it. If it does not try cleaning the drive laser lens with a CD lens cleaner available at places such as KMart or WalMart in the electronic section. If that still does not work chances are you laser on your drive is bad and needs replaced. It will need servicing.
Dec 03, 2010 | Samsung HT-Z210 Theater System
DVDs freeze every few seconds while playing
this could be from a number of issues. first is it a home made disk? second the type of changer you are using?
home made disks can be fixed by using a + or - disk depending on the disk and what the drive likes.
as for the second issue it could be a cooling issue or the lens might be dirty try blowing it out with some can air and try to use a lens cleaner disk. they should be able to sell one for about $5 - $10
Jul 07, 2009 | Samsung HT-HDP40 System
Need region free codes
You can try this one it worked on my home threater system
  • Power On with empty tray (No Disc will be displayed in the DVD control panel)
  • Press the Enter button on your remote control
  • Press the buttons 8, 4, 2, 6, 9 and Enter button on your remote control
  • Tray will Open automatically
  • Close the tray on the DVD player
  • After 15 seconds have elapsed, power Off your player (switch the unit to stand-by mode) and then power On your player
  • Finished and ready to play all regions
hope this helps
Little Dish Fitter
Apr 20, 2009 | Samsung HT-TX72 Theater System
DVD play
Try "0000" or "1234" and hope for the best. This code is frustrating to clear by other means...accordianman
Mar 01, 2008 | Koss KS3102 System
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
Koss KS3102 - Audio Problems
I think I have had the same problem. It seems like the system resets itself randomly. I think if you first turn it on in AV-1 or AV-2 mode, then hit the menu button on the remote, then scroll to ihe 'input'option, hit that then pick 'digital'. Do this for both AV-1&2. UI hope this fixes your problem!
Dec 19, 2006 | Koss KS3102 System
Koss KS3102 System Logo
114 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Ekse
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
