Question about Dell 3100cn Laser Printer
Right margin gradually chopping off
When printing, the right margin gradually get chopped off more and more.  I have to reduce my percentage to 90% now so that I can read all the print.  Why is this happening?
  • 1 more comment
  • tcissell Feb 11, 2008
    I have the same problem with about 8 of our Dell 1700 printers. All of the sudden the print gets very light then all the print shifts to the right and cuts off the text on the right-hand side. Have tried removing and reinstalling original drivers (from CD and from Dell's web site) to no avail.
  • cathy1mw Aug 15, 2008
    There is a vacant band vertically down the right side of the printed page... I replaced the drum... After printing a couple of pages with the NEW drum the problem went away for a few pages and then RETURNED. Whats the deal?
  • edfromut Aug 21, 2008
    I have the same problem. The right side is gradually getting more and more chopped off. I have replaced the drum and the toner cartridges but the problem is still there. Does anyone have a solution?
REPLACE DRUM
Posted on Feb 02, 2008
REPLACE DRUM
How to cook pork chops
Yum, I love Pork Chops and Taters. I use a skillet and a little olive oil. Heat the pan til oil is pretty hot, you want to sear the pork chops when they hit the pan for about 2 minutes on each side. Then reduce heat to a simmer, add about a 1/4 inch of liquid to the pan. (I use water) Simmer until cooked. Do not overcook as they can become very dry quickly. That's why I add the water and turn the burner to low.
Also, I make this at least once a month;
Cut chops into 3 to 4" strips
Peel a few potatoes, diced (white preferred)
Put olive oil in skillet (get hot)
Add potatoes, searing the outside
Add pork strips, sear for 2 minutes on each side or to desired brownness.
Reduce heat to simmer
Add water to cover the bottom of the pan
Cover
Let them cook slowly while you watch your favorite show or mix up a salad!
These are so tender and juicy!
Enjoy!
Aug 05, 2017 | Grilling
My printer -X1185 prints the page with a 3 inch blank area on the left side and some of the right side printing is off the page. This is typical in my e mail page, and even if I center the letter on...
Web site designers create Web pages for display on a monitor, not for users to print on 8.5- x 11-inch pieces of paper. This becomes obvious the first time you try to print a Web page. Content you need may get chopped off by the right printer margin, whereas content you don’t need, such as the site’s copyright information, will print on its own sheet of paper. Fortunately, you can avoid such problems with a little foresight.
Before printing any Web page, open Internet Explorer’s File menu and select Print Preview. The current Web page will appear on-screen exactly as it will print on paper. Scan the preview carefully. If it appears that some content is chopped off by the right margin, click the Page Setup button located directly to the right of the Print button in the upper-left corner of the Print Preview window. In the resulting Page Setup dialog box, adjust the left and right margins so that each is set to 0.25 inches. The extra inch of space you gain by resetting the margins should provide just enough room to accommodate all of the content on most sites. Click OK to save the changes and return to the Print Preview window.
Next, scan the preview to determine which pages contain the content you want to print. Take note of those pages and click the Print button in the upper-left corner of the Print Preview window. Locate the Print Range heading and select the Pages option. Type the number of the first page you want to print in the From field and type the number of the last page you want to print in the To field. For instance, if you want to print just the first three pages of a Web page’s content, type 1 in the From field and type 3 in the To field. If your browser doesn’t have To and From fields, type the range of pages (such as 1-3) in the corresponding field. Make sure your printer has paper and click Print.
May 04, 2008 | Office Equipment & Supplies
Why does my Deskjet 1050A printer chop off 1 on the left side of a document I am trying to print?
If the only thing that you REALLY need to print is the last couple of pages then why not just print them only and correct the margins if need be. just a thought.
Dec 07, 2015 | HP DeskJet Office Equipment & Supplies
Brother MFCJ870DW Cuts Off/Chops Off/Truncates Left Side Return Address By About Half An Inch On #10 Com Envelope, Suddenly Started Happening
Check carefully that you have specified it to use the # 10 and that the format does not include a wide margin. If that fails, try printing the Return address 'right justified' and see what happens.
Feb 01, 2014 | Office Equipment & Supplies
Which axe should I use for chopping?
For fine chopping using a side axe this sometimes is a positive effect however, felling with a double bitted axe is not recommended because it's extremely reduces the efficiency.
Apr 18, 2013 | Tools & Hardware - Others
Feb 03, 2013 | Garden
How to us cusinart 11 cup food proceessor for chopping. cutting.
You can download the user manual for the DFP-11 from
http://www.cuisinart.com/parts/food_processors/dfp-11.html
Click on the "download user manual" hypertext link on the right under the processor picture. You need to have Adobe Reader loaded to be able to read the manual.
Please rate this solution. Thanks.
Oct 22, 2009 | Cuisinart DFP-11 Deluxe Food Processor
Image is partially cut off when printed
Your expert patiently talked me through several possibilities. Finally, in the print set-up window, I clicked on Properties in the upper right and made all my printing choices there. I still got a border, even though I didn't want one, but it was all the way around the photo...not on two sides, and the photo was not chopped off.
Aug 11, 2008 | HP Photosmart 325 InkJet Printer
Borders outside printable area
Adjust the margins in the software you are using.
Nov 08, 2006 | HP OfficeJet 5110 All-In-One InkJet...
Dell 3100cn Laser Printer Logo
158 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
