Question about Kenmore 24932 Top Load Washer
Bleach dispenser hose
How do i get the bleach dispenser hose so i can replace it
  • 5,911 Answers
To access the bleach dispenser hose you will need to remove the outside casing of your washing machine. Follow these steps:
1. UNPLUG the machine first.
2. Remove the console. You will have one of two types of consoles with two separate methods of removal.
a. The first type is a matter of removing the two end caps of the console by lifting up on the end cap from back behind the console and pulling towards you. The cap should just pop off. There will be a groove present on the top rear that you can gently pry with a screwdriver if you can't remove by hand. You will need to remove the philips screw under the end caps and the console will lift up. Be careful not to break the plastic hinges that hold the console in place. You can lift it up and lay it back over the rear panel in a resting position.
b. The second type of console (usually found on some of the newer models) has a retaining clip under each end cap at the front corners. You will need to carefully slide a putty knife between the end cap and top of the machine from the front. Push in to release the retaining clip and lift up. This may be a little tricky trying to get both ends to release together. The console lifts up in the same manner as described before. Again, be careful not to break the plastic hinges that hold the console on.
3. You will find two brass colored clips under the console. Place a flat blade screwdriver in the clip groove on the washer top and push away from you. This will release the retaining clip that holds the case to the back of the machine. Remember how they came off, because you will need to put them back in.
4. Disconnect the lid switch plug from the connector. This is a white plug that is mounted physically to the washer top casing.
5. Lift the lid and place one hand under the front rim of the casing and pull up from the rear towards you. The entire casing should lift off the frame.
6. You should easily be able to access the bleach dispenser hose at this point and make necessary repairs. This is also a good time to inspect the rest of the washer interior and clean underneath.
7. Placing the case back on the frame can be tricky. Lift the lid again and place one hand under the front rim of the casing. Looking down through the lid, place the front of the casing UNDER the frame first and slowly lower the rest to the back. There are two cleats on the frame that must line up with two holes in the casing. Once the casing lines back upbleach dispenser hose - 1.gif on the frame, set it down all the way and pull the back up to meet the casing so you can place the brass retaining clips back in. Place the clips in the groove on the back first, then push down until they snap back into the hole on the washer casing top. You may have to use a little effort to get them back in.
8. Reinstall the console.
I know this seems like a lot, but it is simple if you follow the directions given. Getting the machine case to line back up is the hardest part of the procedure, but you can do it if you take your time. Let me know if you have any further questions. I hope this helps you.
Posted on Jan 25, 2008
3 Suggested Answers
SOURCE: LG Tromm Not Dispensing Bleach
i will figure it out mine is doing the same - sherman@all-waste,com
Posted on Jul 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: hinge next to bleach dispenser broke
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Whirlpool duet dispenser to tub hose keeps cracking/ripping. why?
carefully check the position of the clamp, as the tub moves around during the wash and spin cycles the ears of the clamp been rubbing through the hoses
May 12, 2014 | Whirlpool 8540063 Washer Hose, Dispenser...
Bleach dispenser leaking
After opening the front panel, I found that the bleach hose had cracked with age and was found hanging loose. Just ordered new replacement kit.
Aug 08, 2009 | GE Washing Machines
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
How do you get inside kenmore calypso 110.22062100. I am having a problem with bleach dispenser not working.
Before you go in, have you removed the top portion of the dispenser? You can do that while the lid is still in place. If so, here's how to get in. Take a small flat head screw driver or putty knife. Put a thin peice of cloth over it so as to not mar the finnish on your machine. Using a flash light look between where the top panel and the front panel meet. There will be two flat green peices of metal. Using your putty knife or screw driver, push on these clips towards the rear of the machine while lifting up on the top portion. Once you get the two clips off, you'll be in. For a bleach dispensing problem, I would remove the hose coming off the bleach dispenser side, the white plastic "T" it goes into and the other black hose that goes out to the tub. You could have build up or debris in one or all of them preventing your bleach dispenser. While you have them off, also check the nozzle off the bleach dispenser itself. it too may have a restriction.
Jun 24, 2008 | Kenmore Washing Machines
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
DARK CLOTHES END UP WITH BLEACH DOT STAINS
SOME BLEACH DISPENSERS USE COLD WATER TO FLUSH THE BLEACH FROM THE CUP. CHECK THE COLD WATER FOR GOOD PRESSURE. IF THERE ISN'T GOOD PRESSURE, REMOVE THE COLD WATER HOSE FROM THE MACHINE AND CHECK THE SCREEN INSIDE THE VALVE WHERE YOU REMOVED THE HOSE. PUT THE END OF THE HOSE IN THE TUB AND TURN IT ON. CHECK FOR GOOD PRESSURE. CLEAN THE SCREEN AND RECHECK THE WATER PRESSURE AFTER REINSTALLING THE HOSE AND TURNING ON THE WATER. IF YOU STIL HAVE POOR PRESSURE REPLACE THE VALVE.
Apr 07, 2008 | Kenmore 22422 Top Load Washer
Top Load Kenmore Elite Bleach Dispenser Leaking
I have this same problem today and did not need to take off the top panel or remove the front panel/housing. The bleach and frabric softener dispenser snaps right out and you can check the tubing and clamp from there. You will need to remove the top panel if you need to replace the tubing. In my case, there is a crack in the dispenser itself which has ruined several loads of laundry over the past year...now I realize it wasn't the clamp and hose, but the dispenser itself. Check them all while you are at it.
Nov 18, 2007 | Tecnik TKL9260 Front Load Washer
Bleach/softener dispenser
Try to push a plastic straw through the hole in the dispenser. This hole could be blocked with lint.
Oct 21, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 24932 Top Load Washer Logo
120 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
