Question about Apple iPod MA446LL/A MP3 Player
Frozen iPod Ok. I was about to charge my iPod and put some songs to it. When I plugged my iPod it charged. Then when I opened the iTunes, it read the iPod. I haven't done anything. I was just updating my iTunes, because the iTunes I got was just downloaded. So then, it suddenly unread the iPod, so I safely removed the iPod then it hunged. The "Do Not Disconnect" screen is on. I tried restart but it didn't helped. I can't turn off my iPod.
  • 4,402 Answers
Re: Frozen iPod
You have to try and find a older version of itunes.
you can try sharepod see if that works on it,
Posted on Jan 23, 2008
0 characters
3 Points
How to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
Sep 14, 2010 | Apple iPod shuffle MP3 Player
How to add songs to Ipod
This is a tip explaining exactly how to add songs to your Ipod.
Firstly, you need to have Itunes installed on your computer. You can download Itunes for free from the following Website. It is always best to use the most updated version of this software.
Once you have downloaded Itunes, and installed it, we can continue.
Ok, if you already have MP3 files on your computer, and just want to add this songs to your Ipod, we first need to import all these files to Itunes.Here is how we do this.
To import songs in MP3 format which is already on your computer:
  • Open the Itunes software you installed.
  • From the iTunes File Menu click "Add to Library".
  • Now you need to browse to the folder where the music is located and select it.
  • The files will now automatically be imported to Itunes.
After the installation of Itunes, you need to plug you Ipod into your computer USB port using the connector cable which came with your ipod.
This is the how the USB port on your computer looks like.
This is what the connector cable looks like.
When you have plugged in your Ipod to the computer, Itunes will automatically open.
Now you will be able to see your Music Library(On the left), as well as your Ipod(On the right)
Al you need to do now is to drag the songs you want to copy to your Ipod into the ipod window on the right.
Charge your ipod after you have copied the songs, and start listening.
Kind regards
on Feb 21, 2010 | MP3 & Digital Media Players
Want to just charge my ipod nano using my computer but it's synced with another computers library and don't wan lose my already erased them once even when i chose not to every time i...
Connect it to the computer.
Open iTunes and select the Nano.
Uncheck Open iTunes when connecting this iPod.
Don't have iTunes open when the iPod is connected.
Sep 11, 2010 | Apple iPod nano 5th Generation
My apple classic ipod has frozen,iv jus brout new usb charger/downloader 4 it... how do i charge it through my computer & download songs..& get it 2 unfreeze?
To unfreeze it, try moving the "hold" switch to Off, and the to On again,
and then press the Menu and Center button simultaniously for 10 - 15 seconds, if it works the apple logo should apear and it will start up.
To charge it through your computer, all you need to do is plug it in, and should automatically begin to charge the battery. to download songs you need iTunes which you can get from
Jan 20, 2010 | Apple iPod classic MP3 Player
Hunged-up iPod
this is what i just did with my daugthers ipod, that did not charge nor read hers either, turn on ipod if not still on (kill the battery totally)....later on tonight or when its dead...power up the pc / laptop, bring up itunes then connect the ipod to pc (two things should happen 1 - do not disconnect shoud pop on ipod screen and 2 - the ipod icon should pop on itunes) when updating itunes make sure ipod is not connected.
Apr 09, 2009 | Apple iPod MA446LL/A MP3 Player
Hi. I plugged in my iPod nano 4th generation to charge it. It opened iTunes as it usually does and I could see my iPod in my device list. I left it to charge as normal. I came back a while later and my...
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Mar 22, 2009 | Apple iPod nano
Hunged-up iPod
Usually, unplugging, replugging it and then rebooting solves the problem.
your other options are a driver issue..either with the ipod drivers, itunes, or the USB drivers for your computer itself. since your ipod video and psp work fine, you can rule out USB drivers, but that doesn't rule out additional driver problems.
the other option is there's some kind of failure with your ipod..and sometimes if a device starts drawing power before doing any kind of communication with the computer (like when my rockbox-hacked ipod goes into charge only mode) then windows will assume there's a hardwire issue. the best way to determine if it's an issue with your ipods are take them to another computer and see if they work. if they work fine...try uninstalling and reinstalling itunes (back up your music and database) and see if that solves the problem. if none of that solves it and you know the ipod shuffles are good..then your system has suffered from the mysterious driver failure that's plagued a lot of systems. and generally the only real solution is to reinstall windows from scratch.
Jan 22, 2008 | Apple iPod MA446LL/A MP3 Player
Hunged-up iPod
try to press the menu button and the center b utton at the same will surely help.
Jan 22, 2008 | Apple iPod nano
Ipod Problem (Ipod Nano) moel NO A1199
i fix this problem just the ipod need to reboot
hold ok key and then hold menu key it will be restarted and the it will be connected to your PC
Dec 02, 2007 | Apple iPod Photo MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
37 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
