Question about Bosch Dishwashers
"Check Water" light
The "Check Water" light has come on, on our Basch CLassixx Dishwasher and the base fo the machine is full of water. I have tried "resetting" the machine a number of times but to no avail. What could I try to overcome the problem?
Hi i havee samedishwasher with this same problem, did u manage to fix it, if so how xx
Posted on Nov 28, 2009
I have a bosch dish washer with a E15 error and warning light to check water flow
E15 fault is water into base and has activated the anti flooding device.
You will need to remove the water from base and investigate for leaks.
Jul 10, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch diswasher e15 light
Most likely it is the flood switch trigger causing the problem.
Many reasons for this but mainly it means there could be water leaked into the base of dishwasher where flood switch is located.
Or if you have Aquastop fitted in the water inlet hose then the hose might have kinked due to age or being pressed between cabinet wall and dishwasher. Turn power off to dishwasher at mains plug and pull it out. Check hoses. Tilt it about 20 degrees to one side on a towel and hold for about 10 secs. This should get the water out. Wait an hour or so to dry any moisture in the base and then plug back in and turn on. This should reset the E15 fault.
Apr 21, 2014 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classixx dishwasher
There should be a plastic cover on the bottom, the removal of this gains access to most of the seviceable parts. beware of water spillage when you tip machine into its back!. Good Luck
Nov 21, 2011 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hi, Dishwasher problem: When a programme starts, the machine fills with water then stops and the "check water" light comes on. To empty the machine, I used the reset programme which does empty the...
You will need to check the inlet valve and the water level pressure switch. It can also be a low pressure in the pump that is giving out the signal for the control board to shut off.
So first of all check the water line throughly to confirm.
Oct 02, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Classixx Dishwasher -check water light keeps coming on
thanks i empied my dish wisher old water then it word again thanks Neil Spink
Apr 14, 2010 | Bosch 24 in. SGS43C12 Classixx...
Check water indicator remains illuminated on bosch classixx dishwasher?
caused by anti flood device. machine had water in base caused by minute leak on input hose dribbling down into machine.
Apr 21, 2008 | Dishwashers
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
Feb 23, 2008 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Bosch classixx slimline dishwasher not running through cycle
fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Mar 17, 2007 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
Dishwashers Logo
119 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
