1999 Chevy Blazer makes noise
Check your driveshaft universal joint (u joint). When the needle bearings go, this is the sound it makes. To check, chock all wheels front and rear, put in neutral, if 4x4, put 4x4 in neutral also, go under vehicle, grab driveshaft at u joint and try to turn back and forth, watching for play, wobble in u joint. U should be able to see it. Let me know how u do.
Have you tried rotating the tires to see if the noise changes?
