Question about Apple iPod MA446LL/A MP3 Player
Hunged-up iPod Ok. I was about to charge my iPod and put some songs to it. When I plugged my iPod it charged. Then when I opened the iTunes, it read the iPod. I haven't done anything. I was just updating my iTunes, because the iTunes I got was just downloaded. So then, it suddenly unread the iPod, so I safely removed the iPod then it hunged. The "Do Not Disconnect" screen is on. I tried restart but it didn't helped. I can't turn off my iPod.
  • 4,402 Answers
Re: Hunged-up iPod
Usually, unplugging, replugging it and then rebooting solves the problem.
your other options are a driver issue..either with the ipod drivers, itunes, or the USB drivers for your computer itself. since your ipod video and psp work fine, you can rule out USB drivers, but that doesn't rule out additional driver problems.
the other option is there's some kind of failure with your ipod..and sometimes if a device starts drawing power before doing any kind of communication with the computer (like when my rockbox-hacked ipod goes into charge only mode) then windows will assume there's a hardwire issue. the best way to determine if it's an issue with your ipods are take them to another computer and see if they work. if they work fine...try uninstalling and reinstalling itunes (back up your music and database) and see if that solves the problem. if none of that solves it and you know the ipod shuffles are good..then your system has suffered from the mysterious driver failure that's plagued a lot of systems. and generally the only real solution is to reinstall windows from scratch.
Posted on Jan 23, 2008
0 characters
3 Points
How to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
Sep 14, 2010 | Apple iPod shuffle MP3 Player
How to add songs to Ipod
This is a tip explaining exactly how to add songs to your Ipod.
Firstly, you need to have Itunes installed on your computer. You can download Itunes for free from the following Website. It is always best to use the most updated version of this software.
Once you have downloaded Itunes, and installed it, we can continue.
Ok, if you already have MP3 files on your computer, and just want to add this songs to your Ipod, we first need to import all these files to Itunes.Here is how we do this.
To import songs in MP3 format which is already on your computer:
  • Open the Itunes software you installed.
  • From the iTunes File Menu click "Add to Library".
  • Now you need to browse to the folder where the music is located and select it.
  • The files will now automatically be imported to Itunes.
After the installation of Itunes, you need to plug you Ipod into your computer USB port using the connector cable which came with your ipod.
This is the how the USB port on your computer looks like.
This is what the connector cable looks like.
When you have plugged in your Ipod to the computer, Itunes will automatically open.
Now you will be able to see your Music Library(On the left), as well as your Ipod(On the right)
Al you need to do now is to drag the songs you want to copy to your Ipod into the ipod window on the right.
Charge your ipod after you have copied the songs, and start listening.
Kind regards
on Feb 21, 2010 | MP3 & Digital Media Players
Want to just charge my ipod nano using my computer but it's synced with another computers library and don't wan lose my already erased them once even when i chose not to every time i...
Connect it to the computer.
Open iTunes and select the Nano.
Uncheck Open iTunes when connecting this iPod.
Don't have iTunes open when the iPod is connected.
Sep 11, 2010 | Apple iPod nano 5th Generation
I added my songs off of my cd to my itunes page now ipd dnt charg
this might be the ipod sytem has corrupted reset ur ipod through internet then if the songs are mp3 format copy it to the harddisk and then add to the itunes library or if it is audio format then rip it first then add to itunes library then the songs which are in itunes library will be synced automatically and there will be no charging problem..... enjoy apple ipod
Sep 05, 2009 | Apple iPod shuffle MP3 Player
Hunged-up iPod
this is what i just did with my daugthers ipod, that did not charge nor read hers either, turn on ipod if not still on (kill the battery totally)....later on tonight or when its dead...power up the pc / laptop, bring up itunes then connect the ipod to pc (two things should happen 1 - do not disconnect shoud pop on ipod screen and 2 - the ipod icon should pop on itunes) when updating itunes make sure ipod is not connected.
Apr 09, 2009 | Apple iPod MA446LL/A MP3 Player
1gb ipod
Restore factory settings, if the buttons dont work. This will clear your ipod of all songs.
To revert your ipod to factory settings, go to preferences in itunes. Then go to your device and look for restore factory settings
Dec 02, 2008 | Apple MA950LL/A 1GB iPod Shuffle MP3...
Frozen iPod
you have to try and find a older version of itunes.
you can try sharepod see if that works on it,
Jan 22, 2008 | Apple iPod MA446LL/A MP3 Player
Hunged-up iPod
try to press the menu button and the center b utton at the same will surely help.
Jan 22, 2008 | Apple iPod nano
Ipod Problem (Ipod Nano) moel NO A1199
i fix this problem just the ipod need to reboot
hold ok key and then hold menu key it will be restarted and the it will be connected to your PC
Dec 02, 2007 | Apple iPod Photo MP3 Player
Ipod not charging
Try opening iTunes to see if it recognizes anything first. More importantly set it to disk mode on the main iPod options screen. Remove any songs from the iPod through disk mode into a new folder, (you wont be able to tell as Apple renames and rearranges everything, but you id3 tags should still be recognized when you import after your iPod is fized)Restore your iPod with iTunes. Those are the steps I'd take first. If that works, just re-import those songs into the iTunes library then over to you iPod
Jul 24, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
43 people viewed this question
Top Apple MP3 & Digital Media Players Experts
 Mike M
Mike M
Ron Dufek
Ron Dufek
Raisin Brann
Level 1 Expert
Are you an Apple MP3 and Digital Media Player Expert? Answer questions, earn points and help others
