Question about Cell Phones
Locked santro my car keys for the santro were at the ignition and the switch was on. the car is fitted with an automatic locking device. as soon as i got down the car with the keys still at the ignition the car locked up automatically. i want to know that is there any method to open the car at that point of time without breaking open the glass.
  • sudhishsoni Jan 22, 2008
    i dont know
  • SHANKARMORO Feb 18, 2009
    haVE THE SAME PROBLEM
    SANTRO ZIP LS
    AND DONT HAVE A DUPLICATE AT ALL
    SHANKAR MORO
  • 4,102 Answers
Hi you are in a pridicament without spare key or calling our breakdown service the only way is smash window the only other option is but depending on the car as i dont know the car model you can sometimes carefully remove the back window on the side of the car looks bit like triangle but this will usually break if you didnt want to replace window you could cut away the rubber around this window and remove without breaking but then you might need to buy new seel or some window bond ifthe window is bonded in.
I wish you all the look would like to know what you do
Posted on Jan 22, 2008
6ya staff
SOURCE:
Holden cruze 2009 key stuck in the ignition won't go to off position , can't get it out of park .What is the problem ?
Is it shifter on the floor ?
Ignition Lock Cylinder Control Actuator
If the vehicle is equipped with a floor mounted console gear shifter, it has a ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator's purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in gear and the vehicle may still be moving. The column ignition lock system consists of a ignition lock cylinder control actuator , and a park position switch that is located in the A/T shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded out to mechanically prevent the ignition key cylinder from being turned to the lock position when vehicle transmission is not in the Park position. If vehicle power is lost, and/or the transmission is not in the Park position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
GM had problems with these ! Has a TSB - technical service bulletin !
Automatic Transmission Shift Lock Control Description and Operation
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
• The automatic transmission shift lock solenoid (serviced as the automatic transmission shift lock actuator), as well as the body control module (BCM) and the engine control module (ECM). The shift lock solenoid is located within the floor shift control assembly with vehicles equipped with floor shift.
• The BCM controls the voltage to the shift lock control solenoid through the shift lock control solenoid controlled voltage circuit. The following conditions must be met before the BCM will remove voltage from the shift lock solenoid:
- The ignition is in the ON position.
- The engine control module (ECM) sends an input via GMLAN serial data to the BCM indicating the transmission is in the PARK position.
- The BCM determines the brake pedal is applied according the brake pedal position.
Since the shift lock control solenoid is permanently grounded, the BCM supplies voltage to the automatic transmission shift lock control solenoid, mechanically locking the shift lever in the PARK position as the solenoid energizes. When the brake pedal is applied, the BCM turns the control voltage output of the shift lock control solenoid OFF, de-energizing the shift lock control solenoid. The de-energized solenoid releases the mechanical lock allowing the driver to move the shift lever out of the PARK position. When the transmission is out of the PARK position, the shift lock control solenoid remains de-energized.
During remote start operation, the BCM will energize the shift lock control circuit, locking the shift lever in the PARK position.
Replaced shifter on a cobalt , broken plastic part inside , wouldn't press on micro switch to disengage ! Found replacement shifter at auto slavage yard .$20.00 US
Sep 03, 2016 | Holden Cars & Trucks
This morning it started fine but will not come out of gear and my airbag light is on. Someone said it was the fuse but I am not sure which fuse. Any ideas ?
I am mechanic I really need to no more make ect. but it could be battery or the ignition switch or ignition lock n key but like I said need more information this is a guess that I told you
Oct 21, 2015 | 2008 Chevrolet Chevrolet TrailBlazer LT
Stuck in park will not shift
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control is a safety device that prevents an inadvertent shift out of PARK when the ignition is ON. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components:
The automatic transmission shift lock control solenoid.
The automatic transmission shift lock control switch.
The park/neutral position switch.
With the ignition in the ON position, battery positive voltage is supplied to the park/neutral position switch. When the transmission is in the PARK position the contacts in the park/neutral position switch are closed. This allows current to flow through the switch to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The automatic transmission shift lock control solenoid is permanently grounded. This energizes the automatic transmission shift lock control solenoid, locking the shift linkage in the PARK position. When the driver presses the brake pedal the contacts in the automatic transmission shift lock control switch open, causing the automatic transmission shift lock control solenoid to release. This allows the shift lever to move from the PARK position.
Park Lock Solenoid
The park lock solenoid is a safety device that prevents an inadvertent shift out of PARK when the key is in the OFF position. The key must be in the RUN position to release the park lock solenoid. The system consists of the park lock solenoid. With the ignition in the ON position, voltage is supplied to the park lock solenoid. The park lock solenoid energizes through a permanent ground unlocking the shift lever. With the ignition in the OFF or ACCY position the park lock solenoid de-energizes and locks the shift lever in the park position.
Shift Lever Does Not Move with Brake Pedal Depressed
DEFINITION: Transmission shift lever will not move out of the PARK position with the ignition ON and the brake pedal pressed.
Did you perform the Symptoms - Automatic Transmission Shift Lock Control tests and all the necessary inspection?
Go to Step 2
Go to Symptoms - Automatic Transmission Shift Lock Control
  1. Turn ON the ignition, with the engine OFF.
  2. Press and hold the brake pedal.
  3. Attempt to move the shift lever out of the PARK position.
Does the shift lever move out of the PARK position?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO Go to Step 3
  1. Turn OFF the ignition.
  2. Disconnect the automatic transmission shift lock control switch.
  3. Turn ON the ignition, with the engine OFF.
  4. Press and hold the brake pedal.
  5. Attempt to move the transmission shift lever out of the PARK position.
Does the transmission shift lever move out of the PARK position?
Go to Step 6
Go to Step 4
  2. Disconnect the automatic transmission shift lock control solenoid.
Go to Step 7
Go to Step 5
Inspect for poor connections at the harness connector of the automatic transmission shift lock control solenoid. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 10
Go to Step 9
6
Inspect for poor connections at the harness connector of the automatic transmission shift lock control switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 10
Go to Step 8
7
Repair the short to battery positive voltage in the A/T shift lock control solenoid supply voltage circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 10
8
Replace the automatic transmission shift lock control switch. Refer to Stop Lamp Switch Replacement in Lighting Systems.
Did you complete the replacement?
Oct 13, 2015 | 2006 Hummer H2
2009 Chevy Impala key stuck in ignition
Electronic Park Lock (EPL)/Ignition Lock Cylinder Control Actuator: If the vehicle is equipped with automatic transmission and a floor mounted console gear shift, it has an ignition lock cylinder control actuator system in the steering column. The ignition lock cylinder control actuator purpose is to prevent the ignition key from being turned to the OFF position when the transmission is in any position other than PARK and the vehicle may still be moving. The column ignition lock system consists of an ignition lock cylinder control actuator, and a park position switch that is located in the automatic transmission shift lock control switch. The ignition lock cylinder control actuator contains a pin that is spring loaded to mechanically prevent the ignition key cylinder from being turned to the lock position when the vehicle transmission is not in the PARK position. If vehicle power is lost, and/or the transmission is not in the PARK position the operator will not be able to turn the ignition key to the lock position and will not be able to remove the ignition key from the column.
Does your impala have floor shifter ?
Jan 31, 2018 | Chevrolet Cars & Trucks
04 CTS Ignition Key Stuck, but I can remove the key and restart after a battery disconnect
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of the PARK position. The system consists of the following components.
• The automatic transmission shift lock control solenoid
• The brake switch
• The rear integration module (RIM)
• The transmission control module (TCM) or powertrain control module (PCM)
With the ignition ON, battery positive voltage is supplied to the automatic transmission shift lock control solenoid from the ignition 3 relay. The automatic transmission shift lock control solenoid is controlled by the rear integration module. When the rear integration module (RIM) receives a class 2 serial data message from the transmission control module (TCM) or powertrain control module (PCM) indicating that the shift lever is in the PARK position the rear integration module (RIM) grounds the automatic transmission shift lock control solenoid control circuit. This causes the solenoid to energize mechanically locking the shift lever in the PARK position. When the driver presses the brake pedal the rear integration module receives the brake applied signal and turns off the ground to the automatic transmission shift lock control solenoid control circuit. This allows the shift lever to be moved out of the PARK position.
Step
Action
Yes
No
Install a scan tool.
Does the scan tool power up?
YES - Go to Step 2
NO - Go to Scan Tool Does Not Communicate with Class 2 Device in Data Link Communications
Attempt to establish communication with the Powertrain Control Module (PCM) and the Rear Integration Module (RIM).
Does the scan tool communicate with the PCM and the RIM?
YES - Go to Step 3
Important: The engine may start during the following step. Turn OFF the engine as soon as you have observed the Crank power mode.
Access the Ignition Switch parameter in the rear integration module (RIM) inputs data display list.
Rotate the ignition switch through all positions while observing the ignition switch power mode parameter.
Does the ignition switch parameter reading match the ignition switch position for all switch positions?
YES - Go to Step 4
NO - Go to Power Mode Mismatch in Body Control System
Select the display DTCs function on the scan tool for the PCM and the RIM.
Does the scan tool display any DTCs for the PCM or the RIM?
YES - Go to Step 5
NO - Go to Symptoms - Automatic Transmission Shift Lock Control
5
Does the scan tool display any DTCs which begin with a "U"?
YES - Go to Diagnostic Trouble Code (DTC) List in Data Link Communications
NO - Go to Step 6
6
Does the scan tool display DTC B1000, B1004, B1007, or B1009?
YES - Go to Diagnostic Trouble Code (DTC) List in Body Control System
No - Go to Step 7
7
Does the scan tool display DTC B1327?
YES - Go to Diagnostic Trouble Code (DTC) List in Engine Electrical
This is something best left to the Cadillac dealer !
Mar 18, 2017 | Cadillac CTS Cars & Trucks
What is engine immobilizer
It's anti-theft security system, Nissan Vehicle Immobiliser System (NVIS)
The NISSAN Vehicle Immobilizer System will not allow the engine to start without the use of a registered key.
If the engine fails to start using a registered key (for example, when interference is caused by another registered key, an automated toll road device or automatic payment device on the key ring), restart the engine using the following procedures.
1. Leave the ignition switch placed in the ON position for approximately 5 seconds.
2. Place the ignition switch in the OFF or LOCK position and wait approximately 10 seconds.
3. Repeat steps 1 and 2.
4. Restart the engine while holding the device (which may have caused the interference) separate from the registered key.
If the no start condition re-occurs, NISSAN recommends placing the registered key on a separate key ring to avoid interference from other devices.
Statement related to Section 15 of FCC Rules for NISSAN Vehicle Immobilizer System (CONT ASSY - IMMOBILIZER, ANT ASSY - IMMOBILIZER) This device complies with part 15 of the FCC Rules and RSS-210 of Industry Canada. Operation is subject to the following two conditions; (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation of the device.
CHANGES OR MODIFICATIONS NOT EXPRESSLY APPROVED BY THE PARTY RESPONSIBLE FOR COMPLIANCE COULD VOID THE USER'S AUTHORITY TO OPERATE THE EQUIPMENT.
Security indicator light
For vehicles without Intelligent Key: This light blinks whenever the ignition switch is placed in the LOCK, OFF or ACC position.
For vehicles with Intelligent Key: This light blinks when the ignition switch is placed in the LOCK position with the key removed from the ignition switch.
This function indicates the NISSAN Vehicle Immobilizer System is operational.
If the NISSAN Vehicle Immobilizer System is malfunctioning, the light will remain on while the ignition switch is placed in the ON position.
If the light still remains on and/or the engine will not start, see a NISSAN dealer for NISSAN Vehicle Immobilizer System service as soon as possible. Please bring all registered keys that you have when visiting your NISSAN dealer for service.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 26, 2012 | 2000 Nissan Maxima
How do I remove the steering column lock on a 240 Volvo. I'm trying to tow a car that was left on my property but the ignition key is gone. Also, If I buy a new ignition switch and replace it, will this...
it is secured on by 2 headless security bolts, they need cut off or ground out to get the lock off, but as you say a new lock can be fitted after this and the car started normally, so you can butcher the old lock since you have time and space to do so, and you can move the car as soon as the old lock is off.
Alternatively, you can get a slide hammer (google it) and using the self-tapping screw attachment, screw it into the lock where the key would go, then a few tugs of the slide hammer weight should pull the guts out of the ignition barrel, allowing you to turn it with a flat screwdriver.
Oct 24, 2009 | 1991 Volvo 240
Auto door locks don't work, key stuck in Ignition
If the key is not coming out of the switch, it may be off, but you haven't turned it far enough back that final click to remove the key. Some have a button you have to depress to get the key switch to turn back that final click. That's it.
Nov 13, 2017 | 1994 Oldsmobile Cutlass Ciera
Automatic Door Locks when you start driving
Yes, there is a way to reprogram your car to lock the doors when the gear selector is put into Drive.
Follow this site for a complete step by step re-program of the door locks:
http://www.nialtima.com/automatic_door_locks-113.html
Jan 23, 2018 | 2002 Nissan Altima
2000 Toyota Sienna Minivan car alarm goes off.
1. Start with key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into ignition (Do not turn) and pull it out.
3. Perform these steps within 40 seconds.
A. Using the power door lock switch on drivers door perform 5 lock/unlock cycles starting
with lock. Use an even pace and try to go about one cycle per second.
(1 cycle = 1 lock and 1 unlock.)
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful entry
into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds the door locks
should cycle once indicating successful programming. If the door locks don't cycle or
cycle twice, repeat steps A and B, your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new transmitter.
7. Close drivers door.
Apr 25, 2009 | Chevrolet Malibu Cars & Trucks
Cell Phones Logo
497 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
