Black line When printing on color printer, a black line runs all the way down the center of the back of the sheet.
  • 1,326 Answers
Is the paper you are using a bond paper and a little heavy. The line is most likely comming from the fusing ass'y. Are you running it LTR size? Try runing it LTR-R size. It will not put as much fores on the fuser and it will run a little slower. Also try the by-pass. Or try to run some Blank White pages though it to clean the fusing ass'y. You also may need to rebiuld or replace the fusing ass'y.
Posted on Feb 08, 2008
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    Carrier stall
    The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
    The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
    The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test.
    To self-test the printer, please follow the steps given below:
    1. Press the "Menu" button 10 times. It should then read "Maintenance" on the printer's display screen.
    2. Press the "Select" button once. You should then see "Cartridges" displayed on the printer screen.
    3. Press the "Right Arrow" button 3 times, which then brings you to the "Self-Test" option.
    4. Press the "Select" button once. It should print out a sheet of paper with horizontal color and black lines and smaller vertical lines.
    The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
    If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues and we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
    If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
    Oct 03, 2009 | Lexmark X85 All-In-One InkJet Printer
    Samsung 315 black color fades after 200 of 250 prints
    remove the toner cartridge from printer and shake it well and insert it back and see the result of print
    Sep 12, 2009 | Samsung CLP-315W Laser Color Printer
    Replaced print head and cartridges and still not printing.
    Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost..
    Jul 04, 2009 | Kodak ESP 5 Printer
    Epson Stylus Pro 4800 Never Before Seen Banding Problem
    Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
    May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
    Is there any debris under the printhead nozzle plate?
    Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
    Big black marks down the center of every sheet?
    Jan 04, 2008 | Dell 3100cn Laser Printer
    91 people viewed this question
