Tv turn on now,pictures only flashes few sec. than dies have audio left only?Yes,than the tv 2 long LCD inverter boards are dead.These 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
This all depends on what you want to do. watch TV, play games , watch dvd's... there is no region code associated with the TV, but you might want to check if your TV supports pal and ntsc.
Hello Mendez the problem that your tv set is having is coming from the inverter board this board provides the high voltage for your backlight without the backlight no picture, what i want you to do is go online sometimes this happens go online look for the service manual for your tv set once you find it get it look for the inverter boards location and check the fuse that is on that board sometimes they blow and it will give you this problem if that is your problem you save money and the hassel of taking it anywhere to get it fixed,if it is not the fuse then the inverter board needs to be changed out and that will fix your problem thank you hope this helps.
