Question about Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)
Hdd bad sectore problim
Help me about this problam
my hdd have tomany bad sectors how can i fix this problam
wich softwere can fix it and where did i find it free.
Bad sectors are not fixable as far as hard drives go.
you mmight find software that claims ti fix bad sectors but the claim is false as they only temporarily overwrite the sectors and unmark the bad and remark to good but the problem remains to be the sectors are bad.
The best thing to do is to replace the hard drive with a good used one or a new one.
Sorry but as a technician I know what bad sectors are and what happens when you get them.
Posted on Jan 22, 2008
How to fix damaged hdd's sectors ????????
By the amount of realocated sector count it is conclusive yr hardrive is failing. Back up your data to another drive ASAP and replace the faulty drive.
If you need to get back all your data from the faulty drive and it doesn't work well you shoulod consider HDD regenerator. It is the ONLY software around that works in these instances and it has saved me Several times.
But do no think it will cure the drive !
Like i said: Back up all data & replace the drive ASAP...
Nov 18, 2014 | Computers & Internet
View Link. But under answers, someone mentioned "Bad Sector", after reading the description, any fixits I can do?
When a hard drive has bad read/write sectors it means the magnetic oxide layer on the disc platters are failing. Before you made an image of the hard drive you should have ran Error Check on the C Drive. This checks and locates the bad sectors and moves the data to an undamaged part of the disc platters and then locks out that bad sector so data cannot be written on the bad sector.
I recommend you do a fresh Windows install on your new hard drive to fix this problem and install the laptop's device drivers plus your programs and data before the hard disk fails completely.
Mar 25, 2013 | Computers & Internet
1. read time of hard drive clusters is less than 500ms 2. 33% of hdd space is unreadable 3. bad sectors on hard drive or damaged file allocation table 4. boot sector of hard drive disk is damaged 5. hard...
You can run ChkDisk utility to fix Bad sectors on the hard drive(If its fixable).
This utility actually marks the bad sectors on the Hard drive and Isolate from the being accessed thats why 33% of HDD space is unreadable.(Which is very high)
There is no option to fix this HDD, so suggest you to replace it with a new one.
Hope this helps Let me know if you have any query on this.
Jun 23, 2011 | Computers & Internet
Many Bad Sectors fat32, trying recovery disk
It sounds like your HDD is faulty, usually a hardrive can operate with bad sectors but still a risk.
My best advice would be to get a new HDD and recover back on to the new one, even if you did manage to recover onto your current one you may still have problems in the future.
I usually only allow a HDD to fail S.M.A.R.T tests 3 times over any given period and then I just replace them.
Sep 05, 2009 | Acer Aspire 3000 Notebook
How to remove bad sectors laptop hdd
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Data ligth keeps flashing intermittently and need to reset machine..?can it be a Hard Drive problem perhaps?
possible cause of HDD bad sector or softwere error also check if there are any loose connection between print board & dc.
Jun 04, 2009 | Sharp MX-3501N All-In-One Printer
Buffalo hdd itb with bad sectors
Bad sectors ona drive is normal. The modern High capacity drives actually have more capacity than they tell you so that when bad sectors appear they swwap them out for good ones. So I would not worry about it, unless there are lots. How did you discover the bad sectors?
Go to and download spinrite. That will have a good go at fixing the bad sectors.
Jun 03, 2009 | Buffalo Technology (USA), INC. - 500GB...
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Bad sectors removal and formating Seagate 80 GB
I suggest puting your hdd on another computer, full format it again, and scan it for bad sectors.Also, searching for a program that repairs bad HDD sectors, the windows default erros scan could not be very helpful if there are many bad sectors.
Sep 02, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Computers & Internet Logo
352 people viewed this question
Top Smartdisk - Peripherals Computers & Internet Experts
Arora Singh
Arora Singh
Level 1 Expert
Becky Willson
Becky Willson
Level 1 Expert
Are you a Smartdisk - Peripherals Computer and Internet Expert? Answer questions, earn points and help others
