Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi convergence problem
Have Hitachi 53UWX10B rear projection from 2002. Had convergence kit installed 16 months ago. Last of 4-5 repair visits over life of set. Now it will go in and out of color alignment and picture is curved @ top and bottom toward center of screen. Problem is only intermittent for last 6 weeks. Picture is fine and then sometimes it starts acting up. I suspect the possibility of a loose connection since when prob starts if you tap side of cabinet usually will go back to normal. One service center said they just want to come and replace convergence kit for $500.00 or so. That stinks!! Don't think this TV is worth that kind of investment, especially if repair will only last a year or so. Also I found in basement a box of assorted resistors a tech must have left here on one of the visits. There must be 300-400 total they must be worth something to a repair tech, right??
  • 2 more comments
  • Bob Jan 22, 2008
    Thanks will give it a try. Is best access to this board from front or rear of set?
  • Bob Jan 22, 2008
    Can't work on set now. may be a couple days before I get to it. I am optimistic that this will solve problem. What are your hours of availability in case i have any questions at that time?
  • Bob Jan 29, 2008
    Was able to recreate problem by pushing on heat sink, but not without difficulty.
    Also just found out that set will randomly turn itself on. Have to leave unplugged to
    avoid this. Is this sign of different or additional problem?
  • Bob Jan 29, 2008
    I was looking for feed back to my last comment before proceeding with original repair suggestion.
    Does the additional info I posted change the original diagnosis? Can I get a response>
  • 579 Answers
You need to re-solder the circuit board that contains the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall, about dead center in the circuit board. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. Take the appropriate cautions working around the high voltage of the set & use a non-conduting piece of wood to push the heat sink when we doing tests.
Best of luck, hope ya fix it.
Posted on Jan 22, 2008
  • Anonymous Jan 22, 2008
    morning is best.
    Take rear panels off, label the cabling, remove the board where you can see well the soldering.
  • Anonymous Jan 30, 2008
    The turn on problem is different than the convergence one but may well
    be also due to bad solder joints somewhere. Very unusual problem
    though.
6ya staff
SOURCE:
Hitachi 53uwx10b
thats the sign of failed convergence. You can get the Hitachi DP14G convergence repair kit which also contains instructions from the following link http://www.tvrepairworld.com/hitachi_repair_kits then just scroll down to the DP14G convergence repair kit.
Aug 04, 2012 | Hitachi Televison & Video
My screen slopes from one side to the other on bottom!
Convergence on ur tv are dead.Must know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to fix it urself.The shop will cost u $300 for parts and labors.
Mar 25, 2010 | Hitachi 53UWX10B 53" Rear Projection...
How do you replace a Convergence Amp IC's on projection Hitachi tv?
The DP14G convergence repair kit from www.tvrepairworld.com is the correct kit for your model and the kit contains the parts and the CD with instructions.
Nov 03, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I have a hitachi 53fdx20b and the red and green colors line up fine, but the blue is droopy at the top and doesnt line up elsewhere, any help?? :)
Ur convergence is dead.U know how to solders?Try this website,Tv repair World.com.to buy a convergence kit,replace what in that kit.
Oct 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B Convergence Problem
Had the same problem with so I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step pics of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. Try them
Louis
Jun 19, 2009 | Zenith R49W36 49" Rear Projection HDTV
Ineed to know what convergence ic's are in this tv
Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B Red giving problems
Good Day,
Welcome to the world of having a convergence circuit problem. There two things you can do; get it repaired by a Factory Authorized Service Center or repair it your self. Purchase KIT 10 from B&D Enterprises, 1-800-458-6053. The kit has everything you will need except soldering equipment and experience. Good Luck, big IRISH.
Sep 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
53uwx10b,hitachi
dactag,
Working backwards now.......The burning smell will be the current limiting resistors near and in the circuit of the IC's
you changed..1 to 2 ohms, 1 or 2 watts.....caused by generic
replacement IC's STK392-110,120 or 150......Here is what to do to FixYa! First,please read some of my solutions for convergence
repairs...any brand,the info is generic,the repair parts are not....
1) REMOVE cheap IC's ! Replace with Hitachi part # CZ 01341
upgrade Mfr by Sanyo STK394-160
2)Replace any / all burnt or changed value resistors
3)Re-test to see any symptom....DO NOT CONVERGE
4)Think about putting the original DCU back,since it was
not the problem .......
5) Now where are we at ?? ............................T.
Feb 05, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
42 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
