Question about HP Pavilion dv4165cl Notebook
Laptop get freeze
Hi, My problem is that my laptop gets freeze all the time and only function when I apply some press on the left side of it. What can I do to repair it?
    Sergeant:
    Champion:
  • 306 Answers
Sounds as if the hard drive is not seated propperly, try removing the hd and reinsert it....let me know
Posted on Jan 22, 2008
When i push the e,b,t,a,n ,or r button on my keyboard i get e3 ,bt5,a1, r is shif and nyt
I have often deal damage keyboard, and type of damage keyboard so much. For damage your experience, a variety of ways have been tried, but the result always failed. The best solution is replace keyboard.
Based on experience, three times I fix keyboard, without having to replace with a new keyboard.
First type of damage
All keyboard keys are not functioning, or functioning left side, right side not working
Solution
Remove the keyboard, and cut keyboard cable.
Second type of damage
When laptop is powered on, the sound (tiiiiiiiiiiit) so hard. When we press a button, suddenly appeared equal. example;
I press "y", y appears =======================
I press enter, appear =======================
Solution
Press and release button ~ ` , do it
repeatedly, when turning on laptop until laptop access the operating system.
The result is
1. When laptop turned on, there was no sound. Laptop turns normal.
2. When I press buttons, does not appear equal to. So all buttons normal function
3. There are three buttons that do not function [ { , ] } , \ '
Third type of damage
When laptop is powered, it looks normal. After entering the desktop, buttons z, x, a, s, q, w, e, does not work. If another buttons is pressed, appear equal. example;
I press p, appear p=======================
Solution
Do not turn on laptop (about 3 weeks)
This solution does not make sense, there is no technical explanation, and this solution so strange.
The fact that I experienced
This case occurred on the Acer Aspire 4736z, OS Win XP Prof.
After laptop not turned on, more than 3 weeks, keyboard returns to normal. All buttons are functioning normally. I can not explain technically, but this case never happened.
Solutions for you
I hope this information useful.
Dec 04, 2011 | Toshiba Computers & Internet
My toshiba sattilite laptop, soft touch cursor is not moving and opening the icons
Hi jilglh...
Try this method
To fix an unresponsive touchpad on your laptop, reactivate it by using the Function key on the keyboard and the Fn key.
This process is different for each computer manufacturer.
If unsure which Function key enables and disables the touchpad, try each one at a time and then
attempt to use the touchpad after each one.
A...Locate the "Fn" key of the laptop keyboard.
The "Fn" key has different colored text or the key is a different color.
B...Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
C...Press both the "Fn" and touchpad Function key at the same time to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Note: Mac computers use "F2" to enable and disable the touchpad.
D. Sony Vaio Users: Start>Settings>Control Panel>Double click the Mouse icon.
Look at the top left hand side of the page, at the top and make sure that the "Tapping" box is unchecked, if it is checked then, you will uncheck it.
Please take time to rate me thumbs up
Sep 17, 2011 | Toshiba Computers & Internet
I need tp know how to unlock my touchpad for my Presario CQ62 laptop
Hi lilzett14...
Try this solution to your problem
To fix an unresponsive touchpad on your laptop, reactivate it by using a Function key on the keyboard and the Fn key.
Sep 16, 2011 | Computers & Internet
Touch pad not functioning
Hi jon bernardo...
Sep 11, 2011 | Toshiba Satellite Pro L300 Notebook
Touchapad not working of my laptop hpprobook 4510s Help me for the same ASAP
Hi palkarprasha...
Sep 10, 2011 | HP ProBook 4510s FM849UT Notebook
HOW TO DEACTIVATE TEH Fn KEY IN DELL LAPTOP
Hi names Rui, to turn Fn in you dell you need to:
1. Open your laptop and turn it on. Then locate the Fn key. It is located on the lower left side of the keyboard, next to the Ctrl key.
2. Press and release the Fn key. Now examine the keyboard carefully. You'll notice that many of the keys have icons or letters and numbers printed in blue upon them. These keys and functions are operated when the Fn key is enabled, as you've just done. Test it out by looking at the lower right side of the keyboard. You'll see two keys with small blue "sun" icons. These control the brightness of the screen. Press the lower one several times and you'll see the screen darken. Press the upper one. The screen brightens.
3. Press and release the Fn key again. Now try using the brightness keys. The screen brightness will not change. You've turned off the Fn key.
The Fn key (also known as the Function key) is a feature found on most laptop computers. The Fn key allows keys on a laptop computer's keyboard to serve more than one function, a clever way of increasing the utility of the keyboard when space is limited. Dell laptops make good use of the Fn key, and if you own a Dell laptop, you should be aware of where the key is and how to use it. So i hope this will help you.
Jul 20, 2011 | Dell Vostro 1510 Laptop
Hangging issue
this problem is common in all laptop. freezing and hanging. this is due to an improper cooliing of processor. you need to dismantle the heatsink side and clean, dust and apply silicon thermal paste to enhance cooling. it should not freeze anymore.
Feb 25, 2010 | HP Computers & Internet
T-43 Laptop - Screen freezes, mouse freezes, all functions stop..
The Touchpad is pressure sensitive, you can program the Touchpad's functionality. Go to Control Panel, click, to open Mouse Properties. Click the Device settings (block), select the Settings button; after the Touchpad Wizard appear! "View the (left) "Select an item" pane, and click to start the Touchpad's actions." Follow all the instructions carefully. I hope this Fix it
Jan 21, 2010 | IBM ThinkPad T43 Notebook
Pavillion TX 1215 - Blank Display - HP WHY are you cheating.??
Is the techo going to re-solder the video chip to the motherboard and get the laptop going again, or is he recommending a replacement motherboard?
The overheating problem could be causes by a faulty fan (stop spinning or spins slow) and or dust clogging the fan and heatsink assembly.
The cost of repairing or replacing the motherboard may not be worth it and may be better to put the money towards a new laptop.
You can used the old hard disk by putting it into an USB hard drive adapter case and use it as an external USB hard drive.
Jul 22, 2009 | HP Pavilion tx1000z Notebook
Function keyboard turned on advent QT5500
Hi
Try this my friend,
Press F12, Num Lock, and FN at the same time.
OR F12 and Num Lock/ Scroll Key.
OR Hold the Ctrl and Fn key down together and press also
the Ins(Num LK) key.
Post me whatever the result is... so we could Fixya the problem.
Feb 03, 2008 | Computers & Internet
HP Pavilion dv4165cl Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
