Question about Philips 46PP9302 46" Rear Projection Television
Philips 46PP9302 46 in. Rear projection -
Problem:
TV plays sound but has NO PICTURE. The screen is totally black and nothing is displayed on screen even from the menu.
  • 1 more comment
  • George Lam Feb 20, 2008
    power on but no picture has di di di sound . please tale me what is the problem.
    My e-mail george.lam@supercom.ca.
    Thanks your time.
    George Lam
  • shabbz Mar 31, 2008
    my tv is not showing any image ,its totally blank and there is even no sound.where to repair it in delhi and could u please give me their contact number so that i can get in touch.
  • GWBrad May 02, 2008
    My TV was fine but my oldest son decided to reset the picture to factory settings. After that I tried to manually converge all the colors. It seemed to work that night, but the next day the picture had a shadowy effect. We tried to adjust it but to no avail. We finally got it back to a poor picture but a picture. Now we have no picture but initially when it is powered on colors can be seen, and then it immediatley goes to no picture, black screen. I have tried adjusting the colors inside the TV but have had no success.
  • 579 Answers
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Posted on Jan 22, 2008
  • Philips Master
  • 3,459 Answers
Common problem with the older projection Magnavox TV set. The opto IC chip has failed. Try www.magnavoxhelp.com - They have instructions and kits on their site.
Posted on Jul 04, 2008
Akai 54 inch PT5492S projection tv
try to degauss the screen....
here is a a little guide on how to do it if your tv doesnt have the option
http://www.wikihow.com/Degauss-a-Computer-Monitor
Dec 29, 2007 | Akai PT5492S 54" Rear Projection...
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
SOUND BUT NO PICTURE
is it nothing on the screen at all? if so your projector bulb blew. they usually cost a coupole hundred bucks
Mar 07, 2009 | Philips 60PP9363 60" Rear Projection...
Philips 32" lcd hdtv. HDTV no longer displays, but sound still ok
I reset the comcast cablebox. I totally unplugged the cablebox for 20 seconds and then plugged it back in. Turned on both the cablebox and the tv and the HDTV channels operated correctly.
Dec 08, 2008 | Philips 60PP9202 60" Rear Projection...
I have a sony 61HS10 rear projection tv. The small displays work, showing two or more pictures at the same time but when you want to display just one large full screen picture there is sound but no pi
As you told big picture freeze is working ,then there could the problem in the main processors which not to able pick video input signal ...If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:http://servicemanuals.vstore.ca/ which also contains the part number incase you need a new part...
Good luck.....
Dec 06, 2008 | Sony KP-53HS30 53" Rear Projection...
Where to get repair information on Philips 50" TV
Is the red light on, on the front of the set? If so there are a few things that can cause this, the most common is the fly back transformer/trippler. This is somewhat of an easy fix if you know how to solder and use a meter. If a repair man comes to do it you will be looking at somewhere between $400-$500. Let me know if I can help you more?
Tim Nolan
Sep 12, 2008 | Philips 60PP9202 60" Rear Projection...
No Picture, No Sound
You can get a repair kit from www.magnavoxhelp.com for under 30.00 dollars.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 46PP9302 46" Rear Projection Television Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
